looking for £80 including the hood + delivery The Tamron 70-300mm F4/5.6 DI LD Macro lens is a lightweight, compact, high-image-quality telephoto zoom lens with macro capability of 1:2 that can be used with digital cameras. This ens is a Di type lens using an optical system with improved multi-coating designed to function with digital SLR cameras as well as film cameras. With this 70-300mm telephoto zoom lens, flipping a macro switch in the focal length range of 180mm to 300mm obtains a maximum magnification ratio of 1:2 at a minimum focus distance as short as 37.4", enabling close-up shots of flowers, insects, and other objects that normally require the use of a specially designed macro lens. Moreover, this is a zoom lens that casually offers the distant capture and foreshortening effect pleasures of the 300mm ultra-telephoto world. Visit Tamron's interactive site for more information on focal length and depth of field, plus see an Interactive guide to Tamron Lenses Specifications: Lens Construction (Groups/Elements): 9/13 Angle of View: 34°21'-8°15' Type of Zooming: Rotation Diaphragm Blade Number: 9 Minimum Aperture: F/32 Minimum Focus Distance : 59in.(1.5m) in normal setting/ 37.4" (0.95m) in macro mode (f=180mm-300mm range) Macro Magnification Ratio: 1:2 (at f=300mm MFD 0.95m) Filter Diameter: 62mm Weight: 435g text me on 07921837083
