Does any one know if you can put a clutch plate on the wrong way round just put 2j in with r154 and I ain't got a clutch any suggestion on what could be the problem.
Clutch is really light goes all the way to the floor. when the car is running put your foot on the clutch it goes to the floor but it won't go in gear. Some times the clutch doesn't return.
Yer we bled it, serval times, when u look through the inpection cover whilst someone is depressing the clutch pedal it's like the clutch doesn't engage enough. We tried putting a socket on the end of the slave rod to extended it so the clutch engages more but that made no difference either
yer it fully extends Its all come from running cars, the gearbox (r154) flywheel, correct slave, realease bearing and clutch (used but almost new), beau bought the gearbox and everything from a running mk3 2jz supra which died of rot, the engine came we used came from an aristo, pic of flywheel here in his build thread.... http://www.driftworks.com/forum/drift-car-projects-builds/186763-2-jz-mk3-any-help-welcome.html
