Engine & Drive Train · Toyota 1jzgte · Japspeed Single Turbo Manifold · BorgWarner s256 · Precision 56mm Wastegate · 3 Inch Exhaust with twin 3.5 inch exits · Magna Flow Silencer · 560cc Denso Injectors · Walbro 225lph Fuel Pump · Billet dual feed fuel rail · Civic Type R coil packs · Driftmotion Inlet Manifold · Q45 Throttle Body · Ram air foam filter · Front Mount Intercooler · 100mm Japspeed Radiator · Ford Mondeo V6 Electric Fans · Ny-Trex Wet Nitrous Kit · Front Sump Conversion · Sfs boost hoses · Custom Breather System · Apexi AVCR Boost Controller · Haltech Sprint 500 Ecu · Custom Wiring Harness · Custom Billet Alloy Mounts · Act Extreme 6 Puck Unsprung Clutch · Toyota R154 gearbox With Extended Shifter · Marlin Crawler Shifter Parts · Custom Prop Shaft · Nismo 2way Diff with 4.6 Ratio(needs new ring gear) · 3.9 welded diff fitted · 5 bolt half shafts Chassis · Daiyama S13 Coilovers · Driftworks Geomaster Hubs · Driftworks Front Lower Arms · Driftworks Geomaster Tension Rods · Steering Rack Relocation · Custom Steering Rods With Rose joint Ends · Nismo Power Brace · Subframe Tension Braces · Billet Alloy Subframe Mounts · Nismo Rear Lower Arms · Adjustable Rear Camber Arms · Adjustable Rear Toe Arms · Nismo Rear Caster Arms · S14 5 Stud Conversion · 300zx brake conversion · Abs removed · Braided brake lines · Cusco Front And Rear Upper Strut Braces · Front bumper bar and intercooler mount Wheels & Tyres · Advan Super Racing Version 2 9x17et4 (Front) · 225/45r17 Toyo t1r tyres (front) · Advan Super Racing Version 2 10x18 et9 (rear) x4 · 265 /35r18 Tyres (rear) · 25mm spacers on rear Body · Rocket Bunny Bumpers And Skirts · Origin lab 50mm Rear Overfenders · EP Racing Dmax 40mm Front Fenders · Fiberglass Vented Bonnet · Dmax Boot Lip Spoiler · Aero Catch Bonnet Pins · Origin Lab Smoked Corner Lights · Origin Lab Smoked Rear Lights · Ganador Carbon Mirrors Interior · Fabricage Roll Cage · Driftworks Drivers Seat · Fixed Passenger Seat · Driftworks 4 point Harnesses · Custom Switch Panels · Suede Steering wheel on Removable Boss · Defi gauges (boost, water temp, oil temp, oil pressure) · Apexi AVCR rev counter · Hydraulic Handbrake · Lifeline Plumbed in Fire Extinguisher · Hand Held Fire Extinguisher · Rear Fire Wall · Internal hard fuel lines never thought I'd do this but needs must I've owned this car for around 5 years starting life out as my daily. I'm not in a massive hurry to sell and will be sad to see it go. the bumpers are damaged at the moment but will be getting repaired also one rear light is cracked rubbed the wall at lydden.car is available with our without the advans looking for £10500 without or £12000 with
I think my picture from Wales of this doing a reverse entry will sell it in minutes failing that good luck with the sale!
Still for sale used the car monday at Teesside ran perfect as always, Doing lap after lap with happy passengers.
the size of that rad is almost offensive haha seriously cool car if i could lay my hands on that doller id have it from you glwts bro
this reeks of well built and care just from looking at the parts used i.e borg warner rather than the more rugged and less caring hx35 , the massive rad , haltech ect i want this as a road car but cant afford it atm unless you stripped it to stock and had my soarer that is ;]
Blonde moment Only took you 2 years to take us out, worth the wait, epic car... it even attracts camel toe!
cheers for the replies The car has been developed over a number of years and slowly improved. car is still here keep getting interest but no cash yet.
