Well I have finely started stripping the s14a so I have all the bits for sale. UPDATE! SR20det inc. inlet manifold - SOLD Alternator - £20 Standard Radiator - £50 S14a standard injectors - £40 Power steering pump and lines - £35 Steering Rack - £20 Steering column - £20 Full air-con set up from late 14a - £60 Full Manual conversion - SOLD Standard exhaust manifold - SOLD Standard elbow - SOLD ABS unit £20 standard brake master cylinder - SOLD Red Boot lid with spoiler - £50 Passenger door in Lagun seca blue- £40 Dash - £40 Heater controls - SOLD s14a Headlights - Cracked brackets on one but still mount fine - £150 Laguna seca blue rear bumper UK spec - £30 BC rear coilovers - SOLD HKS nearside coilover - £80 Tein offside coilover - £80 Cusco front top mounts - £50 s14a rear brake set up - £100 s14a front brake set up with good discs and pads - £100 Hel Braided lines - £50 Standard steering wheel - £20 s14a Bonnet in Laguna seca blue - slightly bent on front edge - £60 T28r Roller bearing turbo - SOLD Centre console - £15 Glovebox lid - £15 Boot edge plastic trim - £10 Bonnet prop - £10 Window seals - £10 each Boot seal - £10 Rear section of uk abs prop - £40 Header Tank - £15 Hanbrake - £10 S14a Dials with 149k miles - £80 indicator and wiper stalk - £20 Front seatbelts - £20 Speedo surround - £10 Offside lower arm and tension arm - £30 Drive-shafts - £20 each Brake booster - £10 All located in Pontefract (WF8)
I do yes but thats not for sale atm as need to get the horsham chip transfered out of the old one into the new one so nats works
Bud I'm after the front anti roll bar mount bracket. The one.that hold the bush to the front suffrage?? Pm me if u can help matey Cheers
Went other day to strip it and lost key for wheel nuts so got to sort one of those out before I can strip it
