NOW ONLY £200 , billy bargain Had these to put on my passat but never did as I ended up getting a sweet Ls400 to boss round in. Im sure they are 17x12 rear and 17x9 front, I will have to go to my lock up and measure to confirmation. Stud pattern is 5x112 so im thinking 98% of you guys would need hub converters for these but anyway il see if they sell. Good rubber on all of them. £300 [/URL][/IMG] [/URL][/IMG] [/URL][/IMG] [/URL][/IMG] I am after some 18's with a nice dish to fit my LS400 so im open to PX or what ever. Unfortunatly I cannot post as I work silly hours but could always meet part way at the weekend if it helps anyone. Or if anyone is going the next buxton weekender il pop up with then as its not far from me. Thanks Matt
Anyone wanting to know the finish i.e chrome paint or polished , and the hub bore size. I will try get down my lock up tonight and double check. Im 98% sure the finish is all polished Centre bore = google for passat b5 centre bore size and see what comes up until i can confirm.
Dont the et dude sorry If it helps i can go and measure the dish depth inner and outer? And make a note of tyre sizes at the same time
JA1987 here are the measurements FRONT - PCD plate to outside dish edge - 4inch PCD plate to inside edge - 5 inch 205/45/17 tyre REAR - PCD plate to outside dish edge - 6.5 inch PCD plate to inside dish edge - 5.5 inch 255/45/17 tyre Il try get the photos up later
How much do these weigh approx? For ET... -Measure outside edge to outside edge width and then divide by 2... Thats your centre line -Flip it face down, measure your back space from hub to back edge (use something flat as a rule to make it easier to measure) -Subtract your centreline measurement away from your backspace and there's your offset. I'm interested depending on rough weight and offset bud.
So , Using the values I put above from measurements I took. Face down on a metal flat bench with a metal 1meter rule across the top as an edge line. Offset is 0.5 on both. ????? Does that sound right? As for weight, god knows, though unless they are for competition use does it matter that much? I could always go find my old dears luggage scales and nip to my lock up.
Ahh yea I was doing it in inches. sorry and yea they will go straight on a b5.5 as its just the face lift to what mine was, a b5. All hubs and most of the drive train is still the same.
SO in mm Front - Outside lip to centre - 101.6mm (4in) Centre to inside lip - 127 mm (5in) Centreline : 114.3 Offset : 127 - 114.3= 12.7mm offset Rear Outside lip to centre - 165.1mm (6.5in) Centre to inside lip - 139.7mm (5.5in) Centreline : 152.4 Offset : 139.7 - 152.4 = -12.7mm offset Hope that helps
BUMP, Back from working away and may as well see if i can get these gone, £300, happy to help with delivery upto 45 miles from stoke for people on long runs. Open to swaps on a twist and twat moped - 50 or 125cc must have mot and not too picky on condition, but no scrappers, as its to be messed with anyway for a bsb paddock bike. Or even a monkey bike for shits and giggles. Can add cash if needed.
Just dropped you a PM on the off chance that you could post... or that I can convince my misses that we need to visit the Peak District.
