hought I'd get myself over to Driftworks for a bit of banter and see what you guys think of this. I'm not a purest so have no problems in moving things about to make a better car (2jz in a R33 would be ideal, but no time for that). History. Well I had a little babay R33 GTS Spec 2 running 400BHP and did the odd track day and tried to do some drifting (not that good, but got the basics). I really enjoy track more though. The shell was getting very very tatty and when stripping down the subframe to solid bush it found the mounting points starting to disintegrate. My friend just happened to be breaking a R33 GTR so My idea was to swap all the GTS bits over to it and create a GTRS (later changed to GTSR because I found a badge that suited) It wasn't as easy as I first though, there is quite a lot that isn't inter-changeable especially the front due to the chassis rails of the GTR being different to allow the front drive shafts through. So I'm using the GTS rear sub-frame (as it was already powder coated and bushed) and GTR front subframe/steering rack. Rough spec is as follows (from memory):- GTR ShellGTS Rear Subframe - Solid Bushes - Driftworks lockout kit.Whiteline Arbs. GTS Spec 2 Shimmed diff 1.9mm total shim 1.1+ 0.8 (spec 2 seem to have a 1.1mm shim already where as spec 1's have 0.8) Fully Forged RB25 engine, solid lifter converted with high lift cams, balanced, N1 oil pump. GT3582 Blitz Nur spec Fully stripped, Air con and heater matrix deleted (added small copper core to de-mist the windows) Caged - with added supports Alloy rad with 2 x 12" kenlowe fans, renvotec controller (viscous removed) Greddy inlet with 80mm throttle body. Link G4+ with knock enabled. GTR BC Coilovers with bottoms changed to fit GTS subframe Big brake conversion, not bought new pads yet. Methanol injection kit with custom made beer keg for tank Dual Bosch 044 pumps with swirl pot and fuel cooler 2 sets of:- Rota GTR-D 12J rears Rota GTR-D 10J fronts 1 with 300 and 270 slicks from Porche Cup 1 with 315 and 285 888's Carbon boot with BGW Front is original GTR I was going to use a modified spec 2 GTS front end with wider wings, but after getting front wings that would even come close to fitting I just bought the front end off my mate. Plus loads of other little bits and pieces that you always forget and have to spend ££££ on , nuts, washers, gaskets, sensors etc etc Hoping to get 600 to 650BHP I'm really waiting on the head work to complete and my FMIC before I can get it in to be mapped. Will grab pictures and spec when I can. Any input greatly received. CheersStu
Exterior GTR Shell GTR Bonnet, Bumper (R32 GTR Vents), Lip, Wings Removed wind deflectors to give a cleaner line. Carbon fiber boot. Carbon fiber BGW with high and low mounts. LED rear FOG/Rain Light Std Rear Bumper. Tiberius rear LED lights. Twin Front HID Kit. Interior Triple Dash Pillar holder. Defi DCII Gauges Boost Oil Temp Oil Pressure AEM fuel ratio gauge. 2 x Steering wheel Ripspeed/Momo Jet and Deep dish suede (interchangeable). 2 x Snap off Steering wheel kit. OMP WRC bucket seats. Takata Harness. Dash, vents, gear surround, handles and clocks sprayed silver. Chrome surrounds around clocks. Green lights around clocks. Ikyea Shifter JDM garage gear knob. Sound deadening removed. Electrical Cut-Off Lifeline Fire Extinguisher 6 Point Cage, Modified to 8 point. Added Door Bars and extra supports Air con and Heater Matrix removed Added Small light Heater Matrix Engine Wosner Pistons. Eagle Rods Arp bolts ACL Race Bearings Cometic 1.2 Metal Head Gasket N1 oil pump. Extended and baffled sump Extended oil pick up Head drain kit Greddy Adjustable CAM Pullies Greddy Cam Belt. VVT Deleted. New GTR Water Pump New Tensioners Balanced Bottom End Ported Head Exhaust Side Squish Removed Tomei pro cams inlet 290-11.5 outlet 280-11.5 Tomei Solid Lifters Tomei Springs and Retainers Powder Coated RB26 Cam Covers RB26 change to RB25 Baffled CAM Covers New Core Plugs Greddy Inlet 80mm Throttle Body Steam Pipe Manifold Tial 44mm external wastegate GT3582 Turbo Blitz Nur Spec Exhaust 15db silencer decat Custom down pipe. Custom turbo elbow. Apexi air filter. Air Deflector Panel. Autobahn 88 Front Mounted Intercooler. Autobahn 88 Hard Pipe Kit. HKS SSQ BOV. Walbro In Tank Fuel Pump. Twin Bosche 044 External Fuel Pumps with Swirl Pot Uprated fuel filter. Sard FPR. 680CC GTR Top Feed Injectors Greddy Twin Entry Fuel Rail Grounding Kit. Oil cooler/relocation Kit. Oil Catch Tank. Engine Damper. Japspeed 50mm Alloy Rad Nismo thermostat. Uprated Engine Mounts Twin 12" Kenlowe Electric Fans LINK G4+ Suspension, wheels and brakes GTR BC Coilovers with GTS rear Lowers Whiteline front/rear anti roll bars. Whiteline rear droplinks. CDF front droplinks. Cusco carbon upper front strut brace. GTR rear strut brase. Driftworks HICAS lockout. Adjustable rear camber control arms. Adjustable rear toe arms. Adjustable rear bottom arms. Driftworks Front Tension arms. Japspeed Front Upper Camber arms. GTR Front sub-frame. GTS Rear sub-frame with solid bushes. Diff solid bushes. Poly Steering bushes. Japspeed extended and finned diff casing. 0.8mm shim added to diff (total 1.9mm). EBC redstuff brake pads all round. DB Power Big Brake Kit Braided Brake Lines Bake Stopper Kit ROTA GTR-D 18x10 270x650x18 (too big) front 18x12 300x650x18 Rear (slicks) ROTA GTR-D 18x10 285x30x18 front 18x12 315x30x18 Rear (R888) - - - Updated - - - Place Holder for Pictures
You can box in the front chassis rails and fit a gtst x member if you are so inclined. GTR spider x member does restrict the amount of lock you can run.
That was an idea. I did cut the front off my GTS and compare them to the GTR, but the GTR rails are huge so after boxing in they would be massive and drop the subframe too low. Was even looking at unpicking the rail and remaking it, but that would have made it too weak. I'll have too only drift this for a bit of fun and use it for track.
