Sr20det rebuilt engine in Subaru 2 door impreza big spec drift car
Thread in 'Drift cars for sale' started by pudgey106447, Jul 25, 2014.
  1. pudgey106447
    pudgey106447 Member
    PRICE DROP £3200 ONO .
    HHi have been building this car for past year and now comes the time to sell
    Engine spec is
    rebuilt with acl race bearings
    cosworth head gasket , can be seen
    only a few hours on engine since build
    new plugs
    front mount intercooler
    t25 tturbo
    tubular manifolds
    twin electric fans
    i then spent a lot of time on the shell
    All Subaru front end removed and fitted 200sx subframe
    200sx extra lock hubs
    200sx brakes japspeed track rods modified for extra lock
    200sx japspeed tie rrods
    200sx Bottom arms modified for extra lock
    tein coilovers
    on the rear end there is as much work
    all subaru rear end removed and fitted 200sx subframe
    200sx 3.9 diff
    200sx shafts
    driftworks toe arms
    driftworks camber arms
    jci magic coilovers
    200sx drive shaft
    Other work is
    full subaru 22b wide arch kit fitted
    inside painted white
    aluminium fuel tank in boot
    external large fuel pump
    braided fuel lines
    Original dash with custom made clocks
    Gauges , rpm oil pressure and temp, volts, boost, water temp
    Custom flip switch ignition panel
    Hydraulic handbrake
    custom made carbon fibre rear bumper defused
    carbon fibre front bumper canards
    Bot in roll cage
    car comes on 18 inch ultralight rims aswell as space savers for transport as car is 6ft 2 wide with space savers on ,
    to finish the car needs
    engine set up as larger fuel pump overpowering engine, sard fuel pressure regulator included , but runs and drives
    4 wheel lining but its not bad
    Bolt in cage removed and weld in cage installed
    a little tidy up inside and out to make mint but not bad
    i been building the car but now want a jetski as mates have a couple that's why I selling , would swap for one ,
    car drives and steers but needs a little to finish
    £3500
    07872909883
    live 30 mins from belfast airport and 30 mins from nearest ferry, can collect or deliver from airport or ferry .
    Google Image Result for http://cdn3.spong.com/pack/t/u/tunnelb17638/_-Tunnel-B1-PlayStation-_.jpg
    #1 pudgey106447, Jul 25, 2014
  2. pudgey106447
    pudgey106447 Member
    #2 pudgey106447, Jul 25, 2014
  3. Dantagonist
    Dantagonist Member
    well, that's different.
  4. pudgey106447
    pudgey106447 Member
    Thanks , yeah as great potential to be a awesome driftcar but different to everyone else. , some hours work in this car
  5. crazyae86
    crazyae86 Well-Known Member
    this is awesome car its rare i think b22 engine rigth ?? 2door i like it
  6. GethinD
    GethinD [][][][][][][][][][]
    I love this car. Something really different and well priced, tried to buy it the last time it came up for sale but missed out on it!
    If I wasn't in the final stages of buying a house I'd be on the next ferry over.
    Looking forward to seeing some up to date photos, sounds like you've done a load of work to it since it was last up for sale.
    GLWTS
    #6 GethinD, Jul 25, 2014
  7. pudgey106447
    pudgey106447 Member
    pictures are the same , ill take new ones tomorrow ,only home from holiday yesterday and not had time to refit bumpers, but ill get u ones.
    a lot changed under the car since i bought it almost 12 months ago , nothin to hide mate, i worked a lot on the underside of the car , just never finished it now want a ski as i finishing with drifting.
    lost interest ,
    just bein honest about the thing , the car has nothin to hide ,any parts listed are there plain to see.
    #7 pudgey106447, Jul 25, 2014
  8. Stavros
    Stavros Active Member
    Decent car for the money that, glws
  9. pudgey106447
    pudgey106447 Member
  10. pudgey106447
    pudgey106447 Member
  11. pudgey106447
    pudgey106447 Member
  12. pudgey106447
    pudgey106447 Member
    Price drop £3200
  13. pudgey106447
    pudgey106447 Member
    Friday evening bump
  14. chris-s13
    chris-s13 Member
    I actually really like this [emoji13]
  15. pudgey106447
    pudgey106447 Member
  16. pudgey106447
    pudgey106447 Member
  17. Mr White
    Mr White Drift Bruvvaaaas
    I do really like this for some reason
