Here is my complete manual conversion taken from my mk4 supra which the gearbox was the only good bit of the car. Includes everything needed to convert a 1/2jz engine to manual. Comes with complete propshaft, gearbox, bellhousing, flywheel, slave, clutch, complete clutch release setup. Supra mk4 brake master cylinder with pedal to remove brake accumulator setup. Basicly everything but the pedal. £800 Located Brenzett, Kent near Ashford
Wow! Is scene tax being applied to W58 boxes as well now? R154 manual conversion kit isnt that much more expensive than what youre selling this for. That being said, if you ever decide to split the kit, ill take the box.
Hi mate. Could you give me a text/ring 07891615812 as I am local to you my friend in Germany has asked me to contact you to arrange buying this from you thats ok bud? Many thanks Chris
wouldnt call that scene tax, its not just a box, its a whole manual conversion for a mk4 supra. id say thats about right
It's no where near what iv sold R154's for recently.. I think it's a pretty fair price tbh.. This is roughly what you'd expect to pay for the bits seperatly.. Gearbox With Remote Shifter (late mk4/5 supra version, strongest of the W58's) £450 Bellhousing £250 Prop shaft £120 Clutch & Flywheel £200 Clutch Folk/Release Hub/Slave Cyl £75
right ive now started breaking the conversion. all I have now is the complete gearbox without bell housing, 2jz flywheel with complete clutch looks to be recently replaced. complete propshaft, supra mk4 brake servo and pedal.supra/ big toyota clutch hard line from master to slave. the servo is ideal for removing pressure accumalator setups. all has to go so whoever waves sensible money in my face gets it. no fucking about. I want 400 for the box, 60 for prop. 60 for flywheel and clutch 30 for servo. or if you want it all ill do a deal as all must go asap
