Fit S13/Z32/R32 TEIN UK LIMITED | Products | PILLOWBALL TENSION RODS “TEIN Pillowball Tension Rods are designed to replace the OEM bushing type rods. The pillowball type ends help to improve both vehicle acceleration and deceleration by limiting the movement (deflection under load) of the lower arms. Also increases steering response and reduces roll at corners. The Carbon Steel tension rod includes an adjustable turnbuckle, which allows for adjustment of caster angle for more precise wheel alignment.” Perfect working order £70 + p&p or collect from Welwyn, Herts AL6
U sure bud? The part number is different. If you are 100% sure i will have them. Also you got any pics of the actual arms?
