car updates... it was time to increase further more the steering lock. because i didn't like to destroy what works i bought other pair of used s13 knuckles end i modify them to 0 ackerman angle so the steering from lock to lock is 1 and 1/4 turn this is at full lock the car at open road its harder to steer it and use it but in the track its much much better i use 1 gear up 3rd to 4th gear its pure awesome and 100% diy video its about to come hope you like it
thanks a lot my friend tomorrow im going to order nismotronic, i am going to use a map a iat , boost controller and 1000cc id's
the board from nismotronic just arrived with this board im staying with oem wiring loom and ecu. But i can change to a map iat and electronic boost controller all wired in the ecu. Also i bought from nismotronic bluetooth adapter to send the ecu logs to a tablet that im going to use as a dash here is a video from another guy the fuel rail i bought before 3 months to change to 1000cc id or fic top feed injectors
i bought a egt probe because the old one have been destroyed. the instument works but i don't know how precise it is i have to take measures.
hello all its been a while since you have news i just start to lovate the water cooler at the back of the car for better weight ballance we made custom mounting points and cut the rear for some fresh air next thing is plumping
we moved the fuel tank little bit further, we made the piping the system work's well right now next thing is the naca air vents and test it to the track
yeap exactly it uses usb no rs232 , and u can have a bluetooth to send the information to at mobile device
