S-Body and some E30 parts clear out. (UPDATED) Starting a clear out. Stuff no longer needed or change of direction with project. Will keep adding stuff at a later point. All parts are located in North East England (SR7) Some can be posted, some stuff would need a pallet or collection. Prices do not include postage. Stock s14 T28 turbo, needs a rebuild. Bearing and seals gone. Also has a stud stuck in the exhaust housing but no crack on the wastage - £50 HKS SQV BOV with a T pipe. Not sure if real or fake to be honest. - £40 SR20DET sandwich plate with 4 sender take offs - £15 S13 rear lights, good condition. Been tinted with some funky silver grey paint with metal flake in - £40 Couple of actuators - £5 each. S14 (Zenki) Green grill - £5 S14 (Zenki) indicators and side repeaters - £15 SR20 standard shifter - £10 Full set of engine and gearbox conversion mounts to fit either an SR20DET or CA18DET into an E30 BMW. Mounts are made from 3mm thick channel and TIG welded together. The kit positions the engine and box nice and low, the gearstick lines up nice with the hole in the transmission tunnel. The engine sits nice a low and as far back as possible but still plenty clearance between the sump and subframe and steering rack. The engine mounts are mounted to the engine through hockey pucks, the gearbox mount uses the original gearbox mount. Very strong and light kit. Brand new. - £250 for the lot.
