FS: Weds Kranze ERM 18" (5x114.3) Centre: Chrome / Lips: Polished Fronts: 8J ET9 Rears: 9J ET12 Looking £700 Located Belfast. Willing to ship.
Did a rough estimate a while back by pricing a few different companies and it worked out at roughly £60-£80. Prices may have changed, especially in the run up to Xmas. I'll have a check and see what I can find out for you
Roughly £35 for 4 wheels in 2 parcels (2 large boxes). Box roughly 30kg in weight. If over 30kg then there is a £50 additional charge. Not sure if one additional charge. So either £85 to mainland or £135. Need to look into it more, currently in work, so can't take the time out to check. WheelCarrier.co.uk Rims or Alloys (Without Tyres)
Cheers Danny, been advised with either Paisley Freight or SenditNow. Working out between £30-£40 before insurance
Not sure on the finish Rich, tho they are in need of a refurb. Wouldn't take much to get them ready for prom night
I honestly couldn't tell on the finish tbh, sorry Rich. [EDIT: Just found out that they are chrome centred, with polished lips] I had them on the GS to size up and they sat away from the arches. I had planned to roll the arches and camber all round, just to accommodate them. They sat out roughly 3mm on the front and roughly 5mm on the rear. [EDIT: mm not cm as previously posted
Are you talking about a 1st generation GS? I have 18x9.5 et30 all round on my second generation GS with a 15mm spacer on the rear and they fit fine, the fronts are perfectly flush and the rears could be doing with another 5mm spacer to make them flush. I'm not in the market for wheels but i think you're limiting you market. I can take pictures for any potential buyer to show the fitment because your front wheel will poke out 2mm more and you rears will sit in 3mm less than my than my existing setup so the spec is pretty much identical.
