A change of plans means I have a load of S13 bits for sale.. Got a very solid S13 BARE shell for sale. Needs the bar across the front replacing for the radius arm mounts to bolt too. Has had some seam welding done to it. £500 Viscous LSD £80 Prop £80 Pair drive shafts with rear hubs and brakes £120 Pair Japspeed ajustable lower arms, brand new in box £150 CA box with SR bell housing SOLD Stock injectors £10 each Fuel tank £40 SR20 braided oil lines £40 Rear lights and middle section £50 Moose spec front 4 stud hubs and cross member with rack relocation £220 Stock SR20 exhaust manifold £45 S13 - SR Front mount Intercooler brand new - £175 with pipework S13 - SR Front mount intercooler good condition £125 with pipe work Black stuff rear beam bushes brand new £70 2 x Pair R32 2 door shell doors £20 each door £50 the lot 1 X S13 n/s +50mm fibreglass front wing. Has cracking but easy fix £40 S13 rear subframe bare £25 S14 rear subframe bare £35 SR20 flywheel £40 S13 front stock splitter £40 Located Santa Pod or Birmingham fairly regually.
Bugger! thanks anyway. I dont suppose you know if the rear half of the prop is the same as an R32 do you?
No leaks. Backlash is within tolerance. Not sure how well it locks though, never drove it on a car in all honesty.
