Certainly a change from last time I saw you doing stuff to your old E30. This looks like a great project, keep it up!
Exciting day my car is finally on the rollers! It's making decent power but not sure how much to push it, psi wise, anyone have any advise for me? Like asap!!
On its first map on a bar it made 360hp , we've crept the boost up slightly and made 408hp, how far do I go
Happy with the turbo spool , it's spooling at 2k! On full boost before 3500rpm and hard all the way to 6500 rev limit
Yes happy with is as that's a mega safe tune, so nice and reliable , injectors are only at 65% duty so plenty more potential!
Great build.. What parts did you use to fit the m20 flywheel? Clutch? Etc.. Did you need to modify the flywheel heard about skimming 4mm off the back?
That is great power well done. Reading this is making me want to add a little extra to my z4. Good work :-)
Yeah a few mm machined of the back of the flywheel to clear the sump, M20 clutch disc and pressure plate and I slightly modified the clutch arm to take up the play in the release bearing - - - Updated - - - Yeah a few mm machined of the back of the flywheel to clear the sump, M20 clutch disc and pressure plate and I slightly modified the clutch arm to take up the play in the release bearing
