Bmw E36 compact 2.0 turbo build
Thread in 'Project Cars and Builds Threads' started by James., Dec 28, 2015.
  1. James.
    James. Member
    Haha they sure do!
    The coilovers bolted up fine from the tourer
  2. jay-young
    jay-young Active Member
    Looks great, how much was the cage if you don't mind me asking?
  3. James.
    James. Member
    Cheers chap!
    £560ish from DemonTweeks
  4. georgepoling
    georgepoling Member
    Got the 2.3 in my mx!
  5. James.
    James. Member
    Just been over to your build thread and had a nosey! Looks good! :thumbs:
  6. tiredhero
    tiredhero Member
    nice... what you using ?
  7. James.
    James. Member
    Currently some cheap ebay coilovers. Once the engine is in and running in the future I'll upgrade to HSDs or BCs, but Im a long way from that point at the moment!
  8. georgepoling
    georgepoling Member
    Thanks bud!
  9. georgepoling
    georgepoling Member
    Thanks bud!
  10. driftyste
    driftyste Member
    Been toying with this idea for a while definitely b keeping an eye on this
  11. ratgreen
    ratgreen Member
    Yesss loving the engine choice. How did you go about making the adapter plate. My mate wants to run a bmw box on his b204.
  12. James.
    James. Member
    Cheers chap!
    A mate measured all the bell housing holes and made a template. It was a lot more tedious and complicated than that but we used nothing but a tape measure and a bit of scrap paper to draw on! Every hole lines up perfectly he did a cracking job!
  13. James.
    James. Member
    Been tinkering around with this most evenings after work doing bits and pieces. Got the template cut and drilled on Tuesday, bolted the box up the same evening with some temporary bolts I had kicking around.
    Flywheel came back from the machine shop after being re drilled for the bmw clutch cover,
    Swung the engine and box into th bay to see what things were like, gearbox mounted up near enough to its original mounting points, it's an inch or so forwards but can still select all gears even though the shifter isn't centre of its hole in the tunnel.
    Mocked up where the turbo will be living
    Made some engine mounts up tonight, will get them finished tomorrw then start looking at the sump that will need to be made.
  14. Joss
    Joss Member
    Damn dude quick work. Should be hella cool when done [emoji41]
  15. driftyste
    driftyste Member
    Can't u use a bmw friction plate with the saab pressure plate to save modding the flywheel
  16. spunkeymonkey
    spunkeymonkey New Member
    Looking forward to seeing this built, will plan a cool swap for in a year or so
  17. James.
    James. Member
    Cheers dude! Got to keep making progress else I'll lose interest haha!
  18. James.
    James. Member
    I see exactly what you mean, I think when we pieced it all together we decided that everything from friction plate back was going to stay bmw so it's easier to get parts for. It could well work that way though.
    - - - Updated - - -
    So am I! Itching to get it back on the road:smash:
  19. driftyste
    driftyste Member
    Can u get these bmw box city made to order
  20. James.
    James. Member
    So things have slowed down recently. Attempted to get the clutch/flywheel setup and realised the flywheel is too shallow for everything to line up, so I've purchased a singlemass flywheel from a 9-5 that will be sent off to the machine shop to try and get as close to the oem flywheel weight as possible and the face machined down.
    Ordered a cheap stage3 clutch for the time being, if it holds together happy days if not I'll have to look into something else with no doubt a bigger price tag.
    Engine is currently at a mates workshop having an exhaust manifold and sump made, hopefully get it back this weekend so can crack on with wiring it up and get some progress made! Re mounted the PAS pump where the air con pump was so theres room around the turbo just to make life easier.
    Bought a matching bucket seat and chucked that in over the weekend too.
