Where can I find RX7 FC parts (forum or breaker)?
Thread in 'Other Chat' started by pitesy, Feb 2, 2016.
  1. pitesy
    pitesy Member
    Hello,
    just as above. I am struggling to find a pair of OEM RX7 oil cooler mounts/bushings.
    Is there an active RX7 forum in the UK or a breaker, who might have them in stock?
    They a cost a fortune imported from the US...
    Any help is greatly appreciated!
    Kind regards
    István
  2. Jites
    Jites Active Member
    Do they have to be rx7? Breaking an rx8 which has twin oil coolers with brackets
  3. pitesy
    pitesy Member
    I'm not sure, if they are the same, but they should look like this:
  4. Jites
    Jites Active Member
    Ok, will have a look later
  5. pitesy
    pitesy Member
    Thank you!
  6. Captain
    Captain Member
    Why not just make then out of some steel? They look pretty basic
  7. pitesy
    pitesy Member
    The rubber mounts absorb vibrations and they prevent the alloy cooler from cracking. It shouldn't be mounted solidly on a steel mount
  8. Jites
    Jites Active Member
    Still to check, not back yet
  9. pitesy
    pitesy Member
    I have had a quick google search, they seem to be different.
    I hope the internet is wrong and you have what I need. :)
  10. Jites
    Jites Active Member
    Well it's probably not but I could sell you the whole twin cooler setup or just modify the rx8 ones to fit?
  11. pitesy
    pitesy Member
    Already have the huge RX7 FC version, just want to mount it securely, so it can be a fit and forget part.
    Thanks anyways!
    Any ideas on a breaker, or on a RX7 dedicated forum someone?
  12. Paul-r33
    Paul-r33 New Member
    We really struggled to get parts for our FC, best place to check is US eBay. Postage is expensive tho.
  13. pitesy
    pitesy Member
    Thank you! If I cannot find it here, have to buy them from the US. Do not fancy that, but if I have to.. :)
  14. Captain
    Captain Member
    Is there no way of fabbing them up and just walking some thick rubber on the meeting faces? I'm sure it can't be too hard to mark and would save you alot if time amd money trying to source them from the states
  15. Andy318ti
    Andy318ti Active Member
    Buy anti vibration mounts and make a plate to mount them to.
    Work out much cheaper than importing anything.
  16. pitesy
    pitesy Member
  17. Andy318ti
    That's what I use on mine.
    They weren't that price though.
