Hello, Iam selling a setup from my car (ka24e) it can be easily used on sr20det Price is shipped and paypaled Everything is in very good condition, almost new. Injectors are good for low boost. This is plug and play setup, just remove your old engine wires and put this new one. megasquirt is located in stock ECU place Whats everything included in setup: Megasquirt 2Extra Complete brand new wire installation with some new connectors (fire proof wires) Bosch motorsport coils Injector resistor pack Injectors 370cc (from ca18det) MAP air temp sensor 24:1 tooth wheel for CAS distributor Innovate lc1 controller and sensor Lunch control & flatshift Cable for connection It has integrated bluetooth (Android support) Full registration for TunerStudio
9 grand? Even with an extra zero that's still quite steep for a Megasquirt.... What's the actual price?
900£ ** U got complete fireproof wire for s13 with all sensors, megasquirt ecu like new, 24:1 tooth wheel for cas, injectors, coil pack, wideband innovate and controller. 450£ Megasquirt with innovate lc1 controler and sensor.
