Can somebody help me pick a turbo. I was originally going to be using a GT2871R on an NA-T conversion im currently doing. Hoping for 280hp on stock internals, I have a spare engine which i will be forging with the end goal of 350hp+. Car will be used for drifting. Grassroots stuff, drift days etc Engine is a 1GFE, 2.0 6 cylinder, Lexus IS200 engine. pretty weak and only rev to 6200 The manifold im using is a T3 Twinscroll manifold off a 2JZGTE. I would like some info on both the HX27 (Ill be using a T3-T2 adaptor) and possibly the next turbo up from that I think is a HX30? (I could be wrong) I've read this thread every time there has been an update, never imagined I would be in the situation to be asking for advice. Thanks Matt
If you had a GT2871 already, I'd just use it tbf. Though seems a little bit of a waste of a twin scroll manifold. HX27 is only good to about 300-320bhp, and HX30 only good for, well, over 350 but under 400. Can get twin scroll T3 HX30s, though often they have a fairly large turbine housing, 12cm I think.
You could use a HE221W, good to around ~380hp and should spool fast so 6200rpm rev limit wouldn't be a problem.
Came across an interesting thing yesterday, would appreciate if this wasn't shared around. A friend had an RB25 turbo professionally recored using genuine Holset internals. The idea with the recore is to get a fresh, bolt-on turbo that doesn't shit itself at 1bar. He wasn't chasing a power figure, just wanted to run 1 bar without issues as easily as possible. I know he could run more boost, but the risk of driveline failures goes up (only using RB20 box), as does tyre wear and track time > power figures. Wheel sizes as follows: It seemed too big of a wheel for the housing size for my mind (AR on S1 RB25 turbos i think are 0.5, the OP6 NEO turbine housing is a little larger at 0.67, or so the internet tells me) and thought it'd suffer from excessive backpressure, causing boost control issues at the low boost. Looks like I was right Engine is an S1 RB25 with standard exhaust manifold, custom 3" dump pipe into 3" exhaust. The dump pipe is as large as he can get on the standard flange. He's resigned to needing an external wastegate now which he's annoyed at as it means a bunch more custom work and cost. There is the option of machining the wastegate hole but unknown if this will help. Could this have been avoided with using the OP6 turbine housing or has the rebuilder bitten off more than he could chew with the turbine wheel?
I take it there's nothing you can really do on an inline 5 to decrease lag besides just choosing the best possible sized turbo you can. Sent from my iPhone using Tapatalk
Port match the exhaust manifold to the head and to the turbine housing, turbo blanket, biggest dump pipe you can physically fit (along with exhaust), machine turbine housing and weld on larger v-band PS - i have finally finished reading this entire thread and know what i want to do. I think Stav has repeated himself a solid 20-30 times, he must have the patience of a goddamn saint
Got my hy35 10cm up and running on car took out to run on wastegate presure. And seams a bit laggy. I've also checked shaft play and got a fair bit of up and down movement. I just had it back from compressor raceing after it was passing oil down exhaust houseing. I do everything they say to try and cure 21mm drain- an4 inlet With gauge on turbo to c pressure and all within holset limits. They replace turbine shaft as said machineing wasn't quite right but after speaking to them about shaft play they saying I got a oiling issue and that why it was faulty the first time. Even who they said machineing ( in writing on emails) How much play is allowable. And who do you recommend for rebuild? Also where can I get a 9cm houseing from
Anyone have a link to somewhere I can buy a bolt on adaptor to run a vband exhaust on a hx35? Similar to below
The trick isn't finding the adaptor, it's finding a vband flange the right size to bolt to it, they're usually some weird imperial Size. I just made a little piece up to block off the internal gate path and had it welded in so it was a smooth outlet all the way then had a 3" vband flange welded straight to the housing where the bolt holes are, leaving the internal gate bit exposed cause cause turbulence and affect spool
Do HX35's run a different sized 5 bolt flange to other T3's then? I've got a 5 bolt to V band adaptor on my old T3/T4 To4e replica and wondered if that would bolt straight up???
Totally different. The 5 bolt flange you mean is the old T3 5 bolt you get a lot of old Garretts and loads of Chinese turbos running. The only thing Holsets have in common with them is a T3 inlet flange.
What do people do about the boost pipe v band? Can you get them? Are they a Holset specific size again like everything else?
Stav can you tell me if these guys are selling gen turbos... They seem to be WAY cheaper than the others I see for sale... Holset HX52 11cm 800bhp+ rare T4 quick spool turbo. Not S300 Garrett GT42 GT35 | eBay They have shit loads listed in their shop but heard stories of fake turbos (not these guys just in general)
AWESOME! Love that. HX52s are so under-rated. As they're massive people are scared they won't spool, but they sure as shit do. 100% legit, that's who probably 90% of the Holset turbos seen on cars in the UK come from to be fair. I've known Chris and co for donkeys, basically they work by getting hold of oddball stuff through contacts that's been sitting round in storage or from surplus stuff from tests, and so on, so gets them cheap and can sell them cheap. It's all 1s and 2s found in this way rather than bulk amounts, hence not always having stock of certain turbos. Them Turbonetics he had (has? I dunno), he told me they came from a company who was asked to build some speedboats then stitched up and left with 10x turbos and no use for em, but he knows a good turbo for tuning when he sees one, so snapped em up. Occasionally he will have the odd box fresh never been in storage mega spec turbo, and lo n behold it's £600+ = He's not a charity lol. Small ones, used ones, re-con ones, etc. It's not as if they're selling brand new GTXs etc etc. Good for the money by looks of it, but nothing that rings alarm bells to me.
Hello chaps. Has anyone in this thread had any luck using the internal gate on the holsets? i have a HX35 on a cosworth yb manifold which is twin scroll, and just cant get the boost down. even with a 5psi spring in the actuator it still hits 40psi+. I had a pocket made for the wastegate penny to fully open so i know its not a problem with that. I have been reading that as the wastegate only bleeds off one port in the twin scroll, the other side just keeps on spinning the turbine. I dont really want to go ext gate as its hassle and means expensive mods for my manifold. I have been reading about the mod where people drill past the first hole and into the second scroll on the turbo, but i guess this would make it a single scroll setup then and pointless for what i want. any views?
Hi lad's, I bought this turbo under the impression it was a Holset HX35 but I'm not too sure! Anyone able to advise??? [/URL][/IMG]
