Ex Driftworks JZX110 IRV Factory Manual
Thread in 'Drift cars for sale' started by Wackojacko., Aug 21, 2016.
Thread Status:
Not open for further replies.
  1. Wackojacko.
    Wackojacko. Member
    Evening all, Throwing my latest purchase up for sale due to lack of use and being simply too clean to drift in my opinion.
    I've not long owned the car but in that time I have made various changes and spent a fair bit on it finishing and getting it to what the car should be.
    Quick spec, The build thread is well documented on Driftworks / Google just search Driftworks JZX110
    Factory VVti 1JZ
    HKS 264 cams
    6boost manifold with Garrett GTX3076R and Turbosmart 50mm progate
    Custom super mega clearance stainless 3.5" exhaust - built for PERFECT ground clearance
    QTP Exhaust bypass valve (bypasses all silencers at touch of a button)
    Custom intake on Pipercross filter.
    Driftworks Intercooler kit
    Driftworks remote filter and cooler kit
    Sard 850cc VVti Injectors
    Tomei Fuel pressure reg
    Walbro 400lph in tank pump.
    HKS FCon VPro Gold - HKS Loom.
    HKS Valcon - VVTi controller
    Gizzmo Boost controller with brand new solenoid
    Mapped by protuner - 565bhp & 560ft/lbs
    recent new alternator, plugs & coilpacks.
    ABC twin plate clutch kit - lightweight chromoly flywheel with tilton twin plate clutch, all friction discs & floater plates replaced approx 250miles ago.
    Standard late gen R154 - The strongest of the R154's
    LSD/2way - Not sure what, but locks perfectly.
    HSD Monopro with custom spring rates.
    Modified front hub upright,
    Modified big lock steering knuckles (recent new balljoints)
    Adjustable toe & camber arms
    Modified rear lower arms
    Modified rear beam for exhaust clearance.
    Superpro bushes all round
    Weds Kranze LXZ 19x9.5 et-28, 19x10.5 et-36, great condition, no corrosion and near new tyres all round, also supplied with a spare brand new pair of rear tyres.
    Full Vertex Kit (copy, moulded direct from original)
    Spare vertex side skirts and slightly battered front bumper (genuine)
    Custom steel rear wide arches
    Rear bumber modified to sit with arches.
    Corbeau clubsport seats
    Driftworks hydraulic handbrake (stealth mounted, remote cylinder)
    Nardi deep corn steering wheel
    Full factory interior, in dash screen, jap sat nav, 6 disc system & a very good speaker set up.
    In addition to this spec in my ownership I have :
    Fitted a Defi Advance ZD Digital dash which is a seriously cool but expensive bit of kit. (all the info you need, water, oil pressures and temps etc etc)
    Fresh MOT
    Fresh Rear tyres with two new spare supplied
    Undersealed
    Re aligned and bracketed the exhaust
    Fabricated a tubular front crash bar
    Extensively tidied up the engine bay
    Sorted various boost and oil leaks
    Had the Map and AFR's checked professionally
    Inspected the Diff internals primarily to find out ratio but still none the wiser, all good and replaced with fresh oil
    The car now wants for absolutely nothing which is slightly annoying, but I am unlilkey to use it for the next few months due to work commitments and purely I just think its too clean to drift. The paint is spotless on it, the same guy that painted the 2JZ Etype painted this car and did various bodywork changes and repair on it after the previous owner had a slight coming together with a tyre wall at Castle Combe, all of the repairs are documented, plenty of pictures showing the workmanship that went into restoring and painting the car.
    I am open to PX or £13,000 GBP
    The car is seriously quick, 4 up the other day and it pushed a 997 Carrera down the motorway to the top of 4th gear, I will update with up to date pictures of the car.
    #1 Wackojacko., Aug 21, 2016
  2. Wackojacko.
    Wackojacko. Member
    Bump up we go, still open to PX etc.
    Plenty of interest so far but nothing solid set in stone.
    Plenty of pics on my phone, can send videos and pictures over whatsapp or similar.
  3. euro sbd
    euro sbd Active Member
    Offers still here for the c33 plus cash
  4. Wackojacko.
    Wackojacko. Member
    Up we go again....
  5. AndyH JDM
    AndyH JDM New Member
    Tempted to swap both of my cars for this
    Sent from my SM-G930F using Tapatalk
  6. Wackojacko.
    Wackojacko. Member
    Many time wasters and a few things in the process, it's still here.
    open to offers.
  7. gerryl87
    gerryl87 Member
    Hi mate, can you clear your inbox, cannot pm you
    Sent from my iPhone using Tapatalk
  8. Wackojacko.
    Wackojacko. Member
  9. gerryl87
    gerryl87 Member
    Pm'd
  10. Wackojacko.
    Wackojacko. Member
    Bump up open to offers.
  11. Barnesy
    Barnesy Member
    I've been staring at this for 2 weeks, absolutely a total beast.
  12. SammyP
    SammyP New Member
    Is this still for sale?
  13. Wackojacko.
    Wackojacko. Member
    Hi yes sorry for the delay,
    Still for sale I'm currently not in the country so havnt been pushing the sale.
  14. Wackojacko.
    Wackojacko. Member
  15. Wackojacko.
    Wackojacko. Member
    Bump up.
    Fly to Japan again on Tuesday so offers if gone before then.
  16. -Marc-
    -Marc- -JZX-
    How is this not sold? Awesome car.
    P.S do you basically live in Japan now?
  17. Wackojacko.
    Wackojacko. Member
    £13,000 with all spares
    Spare rear tyres
    Lights
    Skirts
    Bumper
    Clutch
    Pulley kit etc
  18. FordManiac
    FordManiac New Member
    Is this the Kyouto drift car?
  19. MaccyD
    MaccyD Active Member
    No, Driftworks built it. Theres a blog covering most of it on the home page.
  20. sparky_s13
    sparky_s13 Active Member
    Originally DW car, but it was bought buy someone from Kyouto yes
Thread Status:
