* NO LONGER FOR SALE * Hi, It's the RZ model so has the 2JZGTE engine, the V160 6 speed gearbox and the B03B large case LSD, all fitted from the factory and can been seen on the vin plate. imported in 2005 It has MOT til 24 November 2016 and has covered 178,000 Kilometers which works out around 110,000 miles. The car is an import so the speedo has been converted to read in mph but the odometer still reads in km The car is pretty clean underneath with no rust. the body work is good condition for its age. unfortunately the front bumper met a pretty nasty speed bump a few weeks back so will need some attention on the drivers side corner. It drives very well and has recently been to SRD tuning for a once over and to have the sequential turbo system repaired so both turbos now boost as they should. parts fitted in the last year are: IACV vsv engine oil oil filter gearbox oil diff oil battery diff oil seal gearbox oil seal gearbox shifter bushes front brake pads and discs modifications: Clifford alarm with remote start Top secret front bumper and side skirts oem rear spats clear side repeaters Volk GTC alloys 18x10 et22 all round with good tyres HSD monopro coilovers (less then a year old) Apexi air intake filter blitz oil cap alloy radiator dump valve HKS super dragger exhaust both decats Whifbitz restrictor ring NGK iridium spark plugs Defi boost gauge with controller to allow more gauges to be added turbo timer braided brake lines Sony stereo with CD, AUX, USB, DAB bad points: front bumper needs repair SRD said the valve stem seals need replacing as it can smoke on startup (sometimes it starts clean) or if the throttle is blipped after it has been idling. it doesn't smoke under acceleration. radiator fan shround is broken warning light on dash (speed sensor) The car is located portsmouth £12,500 07736796680
About right if you ask me, 15, 16 grand cars are a touch unrealistic unless they're stock and immaculate
I agree with above comments, price seems low for the car, seen plenty of rougher Auto's coming on the market at this price.
