S14a shell clean tig welded fabricage non rolling dash all panels and glass exhaust lights rear frame front frame bumper bar steering column and rack full loom £1500 sold Sr20det build by mnm engineering just had new oem non ground and balanced crank Acl race main and big end bearings new oil pump rotors in October, Wisco pistons, cosworth 1.2 gasket, hks stet 1 in and ex cam, hks rocker stoppers, big wing alloy sump, will include inlet alternator flywheel £1500 sold Borgworner efr 6758 on a custom 3mm wall s/s top mount manifold custom 3" down pipe for s14, this set up made 279whp at 0.7 bar and 323whp at 1 bar on the above engine there is zero play on the shaft it still like new comes with turbo blanket as well, £1100 Hks 6 speed dog box dogleg, bought from Paul at jdm gargae was removed from his personal onevia, bought in September 16 and only dun 2 events come with all you need to put it in a s14 drive shaft tunnel mount also oil catch can and some pipe £3500 Sr20det compleat low comp on no 4 £500 maybe sold Z32 gearbox with spacer plate front prop and selector £500 sold Nistune type 4 in a 14a ecu nats removed £200 sold Oem ecu with nats. £30 sold Nismo 770cc new in September £300 sold Nismo 550cc £150 sold Z32 maf with plug £100 sold Z32 maf with plug, modified so no bolts or adapters £100 sold Competition clutch stage 4 plenty life plate and disc £100 Garret 2871r has play still made boost before removed £100 sold Wisefab front end with Ackerman kit and spare rose joint ends and top mounts £600 sold R33 front calipers and large ebc grooved disc conversion and caliper brackets project mu pads new discs and and in September only been out 2 events £300 Z32 rear calipers with pads and spare pads like new can supply discs but would benefit new ones £200 sold Driftworks rear 3 arms kit new start of last year £200 sold Kazz 2 way diff 4.1 in 14 case with skyline 5 bolt inputs £250 sold Skyline diff 4.3 welded with 5 bolt inputs £200 sold Skyline 5 bolt shafts pair £100 sold Skyline 5 bolt shafts pair £100 sold Corbeau revaluation Kevlar £200 keeping Bride low max £100 sold Bride seat rail drivers side £100 sold Bride seat rail drivers side £100 sold Carbon covers £50 sold Rota gtrd 18x9.5 et12 purple 4 off £500 Rota gtrd 18x9.5 et12 and et20! I think 2gold 2 purple £500 Rota torque 17x9.5 et12 bronze 2 of £250 keeping Cosmis txt-206r 18x9.5 et10 gold 2of £350 Hks boost gauge £30 sold Hks oil p gauge £30 sold Hks water t gauge £30 sold Hks tacho £30 sold Innovate lc2 compleat with recent new Bosch o2 £100 sold Greddy profec b compleat £80 sold Hsd monopros £300 sold Spitfire coils compleat £150 sold Spitfire coils compleat 1 coil faulty kept as spare 3 coils and balest and loom £100 sold D1 fuel pressure reg with gauge £40 sold Reworked Walbro 340 pump new in September from garage Sr £40 sold Blitz bov £30 New wisefab tie roads still in wrapping 2 of kept as spare £50 Will be more items, all parts are still on car and will be striped over the next week or 2 so any parts you need let me know and I'll do my best to get them off first as of photos I'm not uploading photos of every part if u need photos call me and I'll send you photos 07707181568 Location is Fraserburgh north of Aberdeen post can be arranged at cost Sent from my iPad using Tapatalk
Hi mate I'm interested in that 2871r where abouts are you based? Sent from my SM-G935F using Tapatalk
Hi bud, im after gauges, profec and innovate lc2, please send me pm or contact via email - vilius.zilinskas@gmail.com. Thanks.
Ill take the: Hks boost gauge £30 Hks oil p gauge £30 Hks water t gauge £30 Where are you based? 52mm or 60mm? And do they come with the senders?
Oil p might be sold And yeah comes with fittings and so on, 52mm I believe North Aberdeen Cheers Sent from my E6653 using Tapatalk
