900+bhp R33 Gtst
Thread in 'Drift cars for sale' started by scottc1088, Jan 12, 2017.
  1. scottc1088
    scottc1088 Member
    1995 R33 Gtst £18995
    Up for sale is my r33 which iv owned for a few years now, the car was built for track use but has only been used on the road
    Looking to replace with something a little more practical so could px for something along the lines of c63, m5, rs6 etc
    Recently mapped by mgt racing who are well known for their work where it made 861bhp at the hubs on v power
    Mot expires may 2017
    Plate not included with sale and the rust on strut tops will be sorted before sale
    Engine:
    Covered 3k miles at the most since build
    Rb25det block decked and bored to 87mm
    Rb26dett crank bought new from nissan
    Cp forged pistons 87mm
    Manley rods
    ACL race big end bearings
    ACL race mains bearings
    Arp mains studs
    Arp head studs
    Arp big end bolts
    Block oil drain enlarged
    External head oil drain
    Baffled, trapdoor and extended sump
    Cometic 1.6mm Steel head gasket
    Tomei oil pump
    N1 water pump
    Extensive head work
    Ferrea valves
    Tomei solid lifters
    Tomei 270' 10.25 cams
    Tomei valve springs
    Hks adjustable cam pulleys
    Ati gtr crank pulley with trigger
    Cas crank and cam trigger kit
    Splitfire coils
    Vvt removed
    Oil feed to head restricted and other one blocked
    Twin scroll topmount steam pipe manifold
    Borg warner s366sxe billet turbo
    4" turbo back system
    Tial mvr 44mm wastegate
    1000cc siemens injectors
    Front facing inlet manifold
    100mm throttle body
    Walbro intank pump
    Twin bosch 044 pumps with swirl tank
    Teflon braided fuel lines with an fittings
    Aeromotive fuel pressure reg
    Link g4+ ecu mapped by mgt 861bhp at hubs, 900+ flywheel
    Mac 3 port boost solenoid
    Arp flywheel bolts
    Os giken quad plate clutch
    Os giken 1-4 gear set
    Red line shockproof gear oil
    Poly engine mounts
    100mm Intercooler with 3 inch pipework
    Nismo radiator
    Silicone radiator hoses
    Genuine Hks ssqv bov
    Body:
    Full bodykit
    Rolled front arches
    Flared rear arches
    Wind deflectors
    Bride drivers seat
    Dished steering wheel
    Gtr clocks
    Oil temp gauge
    Oil pressure gauge
    Innovate wideband
    Water temperature gauge
    Boost gauge
    Hid headlights
    Chassis:
    Recently been aligned when the geomaster hubs were fitted to correct bump steer due to the angle of arms when lowered on standard knuckles
    Very clean underneath with no rust and recently undersealed
    Nismo lsd that's just had an oil change and locks up well
    Solid diff mounts
    Rota grid drift 18x9.5 front 18x10 rear with new westlake sport rs semi slick tyres all round 235 front 265 rears
    Apexi coilovers
    Driftworks geomaster front knuckles
    Driftworks geomaster rear knuckles
    Driftworks offset steering rack spacers
    Front strut brace
    Japspeed tension rods
    Lengthened front lower arms
    Japspeed front tension rod brace
    S14 200sx steering rack
    R33 gtr power steering pump
    S14 rear subframe with poly bushes to remove hicas completely
    Japspeed camber arms
    Japspeed toe arms
    Japspeed traction arms
    Poly bushed lower arms
    Japspeed rear subframe brace
    K sport 8 pot front brakes with ds2500 pads
    K sport 6 pot rear brakes with ds2500 pads
    Whiteline front and rear anti roll bars
    Any questions you can contact me on 07734181591, viewings are welcome but no dreamers
    Open to offers on price and can px cash either way
    Will add pics tomorrow
  2. scottc1088
    scottc1088 Member
  3. Gazelle
    Gazelle Well-Known Member
    Lovely spec GTST!!!
  4. gtst lad
    gtst lad Ut oh
    Hello mate, i'm tempted here! who built the engine? also what's your rock bottom price? feel free to pm if you don't want to post here
  5. scottc1088
    scottc1088 Member
    Pm sent
    Sent from my SM-G935F using Tapatalk
  6. Jolly F
    Jolly F Member
    What's it's like to drive on the road, it is driveable on the power on our UK roads?
    #6 Jolly F, Jan 19, 2017
  7. scottc1088
    scottc1088 Member
    Depends how heavy footed you are obviously, can be driven normally though as my Mrs uses it for school run sometimes
  8. scottc1088
    scottc1088 Member
    Bump
  9. Jolly F
    Jolly F Member
    Free bump, lovely car, did ask someone about it but I think it's just too much (power and pennys) for them. If you have to end up breading it please let me know.
  10. scottc1088
    scottc1088 Member
    Thanks
    Would break if I had a buyer for the engine
