For Sale S14 TrackCar (Caged, Seats, Big Brakes etc)
Thread in 'Drift cars for sale' started by DavidRuston, Jun 2, 2017.
  1. DavidRuston
    DavidRuston Active Member
    I bought this from DSI in 2016. I bought it because the nasty jobs were already done, it needed a new windscreen but apart from that was ready to use on track., and its been faultless since.
    _MG_3971_zpsqh5uo9mu.
    The day before I bought it I saw this video of it:
    [video=youtube;J07mxI7JOiE]
    I found the prior owners build thread here: http://www.driftworks.com/forum/drift-car-projects-builds/237819-my-s14-track-maybe-drift-build.html
    Current Spec: (bits I have done are in brackets after the item)
    • Stock SR20DET, New OEM Water Pump (02/11/16)
    • Stock T28 welded onto a Tubular Manifold @ 1 bar
    • 3” Turbo Back Exhaust inc Decat
    • Apexi Air Filter
    • Walbro 255lph Fuel Pump
    • Japspeed 52mm Alloy Radiator (new)
    • 2 x Electric Fans mounted on aluminium shroud (new)
    • Unknown Front Mount Intercooler
    • Haltech Platinum Sport 1000 ECU
    • GReddy Boost Actuator (ECU controlled)
    • 60mm Throttle Body
    • Battery Relocated to Boot.
    • Momo Steering Wheel on Quick Release
    • Multi-point 45mm Custom Roll Cage by SuperStyle Garage
    • Sound Deadening Removed
    • Custom Seat Mounts
    • 2 x Corbeau Clubsport Seats
    • 2 x 4 Point TRS Harness
    • 2 x TRS Tow Straps (new)
    • 1 x FIA 3 Point Plumbed-in Fire Extinguisher (new)
    • 1 x MSA Battery Isolator (new)
    • 2 x External Pull Cables (new- Scuttle mounted)
    • HSD Monopro Coilovers with adjustable top mounts
    • Work XD9 Wheels with NS-R2 Tyres (FR 18 x8 ET35, RR 18x9 ET30)
    • 25mm Front Hubcentric Spacers
    • DW Rear Suspension Bushes
    • DW Solid Front Diff Mount
    • Polybushed Steering Rack
    • K-Sport 356mm 8 Pot Front Brakes & Braided Lines
    • EBC Yellow Stuff Front & Rear Pads (New 15/2/17)
    • R33 GTST Rear Brake with Drum Handbrake Conversion
    • Drift Handbrake Button
    • Flat Boot Floor and Custom Jacking Point
    • Boot Pins & Bonnet Pins (new)
    • Rocket Bunny Front Wings
    • Rocket Bunny Front Bumper
    • Rocket Bunny Rear Bumper
    • Rocket Bunny Side Skirts
    • Roof Spoiler
    • Passenger Alloy Footrest
    _17_zpsct1yov96.
    I created a simple centre panel to hold the switched and boost gauge.
    • Relocated ECU to Glovebox
    S14haltechecu_zpslhmx40nt.
    • Removed Air-Con Setup
    • Fitted Side Repeaters
    s14side_zpshpw4ty9n.
    • Relocated Rear Fog Lamp into driver’s side reverse light. - took the standard wiring from behind the bumper and extended it up to the boot lid. Switched to a RED bulbs and done.
    s14fog_zpsg3ht5p2o.
    • Fitted Horn Switch
    • Fitted Japspeed 52mm Large Capacity Radiator
    • Fitted Twin Electric Fan on aluminium Shroud
    s14fans_zps91biogwr.
    • Fitted Front & Rear Tow Straps
    • Fitted Plumbed In-Fire Extinguisher
    s14_fire_zpsg7voii3p.
    • Fitted FIA Electrical Cut-Off Switch
    • Fitted External Pull Cables
    • Fitted New Nissan Water Pump - whilst fitting the radiator I noticed that the old pump was weeping around the edge of the block. Probably just needed resealing as I had been cleaning that area with d-greaser so I think I might have upset the old sealant. But I figured it was a good time to fit a new pump anyway.
    s14water_zps8j67hydb.
    s14_foot_zpsjgygax2a.
    s14_yellow_zpsm4yvvrym.
    _MG_3960_zpsjnkay9pe.
    Its MOT'd until November and fully working. I am not around until Tuesday next week so car will be available from Weds onwards.
    >>More pics on Photobucket here: http://s1279.photobucket.com/user/dwruston/library/200SX S14 Track
    £6500
    Car is located in Hythe, Kent.
    **£6900 if you want the top mount manifold, 740cc injectors etc. setup I have advertised in the parts area as a package
    _MG_4966_zps51n2yf3q.
    s14fire_zpsm8tuhuxm.
    #1 DavidRuston, Jun 2, 2017
  2. crazyae86
    crazyae86 Well-Known Member
    hey there its lovevly car mate
    super clean
  3. Jack Thomas
    Jack Thomas New Member
    Still for sale ? Also how do I contact ?
  4. DavidRuston
    Sorry I have added number to the 1st post, forgot.
    I am not around until Tuesday if you want to come and look.
  5. Adam Fountain
    Adam Fountain New Member
    This is beautiful, still for sale? Also is it still road legal?
  6. DavidRuston
    Yes road legal, MOT'd, Taxed and Insured with REIS. I drive it to and from the trackdays at Lydden and Brands Hatch and its been 100% reliable.
  7. nomaintenance
    nomaintenance Member
    Wat diff is it running? Where are you based? why you selling?
  8. DavidRuston
    Standard Diff not welded, no idea of ratio but it is the 6 bolt type (3 sets of pairs)
  9. nomaintenance
    so where you based? an why you selling?
  10. DavidRuston
    I am in Kent and selling because I have a back problem.
  11. shane_evans
    shane_evans Member
    You have a pm
  12. DavidRuston
    SOLD and Collected
