from here i just couldnt wait for the car to come home i just drove to cork to fit up the sinco and 5858 for the photos haha {} {} also fitted up some r34 gtr brembos {} picked up a fiveomotorsport 340lph avenger pump and a oem oil cooler delete block {} {} picked up some oem spats {} {} {} {} had some crazy hardship with buying a lip and not been posted so i ended up buying two of these rocking horse shit rare bomex lips, so this one is still in transit . hopefully it comes {} s15 dash conversion nearly buttoned up all cluster working {} {} {} odysey pc680 battery relocated to under the pass seat
collected the car from cork got it home and straight into the downpipe, screamer pipe and also intercooler pipes fabbed up to suit the new turbo set up {} {} {} {} {} {} {} {} {} {} {} {} heatwrapped down pipe and screamer pipe, also fitted a ti turbo jacket to be honest i dont have all the photos off all the stuff but i have some time and money invested into the things you do and dont see like all the fuel lines with the bosch motorsport fuel filter, all the torques an lines and fitting. billet servo assist check valve . turbo feed and return lines. etc. i didnt cut any corners at all the car is wired for its standalone fuel pressure sesnor as seen in the fuel reg on bulkhead. wired for its standlone oil pressure sensor for the ecu and these can be set up in the ecu for engine protection so anything decides to try creep up as a problem the car will shut off before i even notice it. maybe it overkill but it is pretty much a all out drift car on the road. also picked up a bride zeta 2 and i bought a brand new bride rail {} the serial999 shifter is a work of art can be seen in the photos above for the s15 dash photos
just mounting up the mac boost solenoid and running vacuums. ive fitted heatsleeving to all vacuum pipes, turbo oil feed and return. im terrified of a fire with it {} {} got a mate to weld on 2x -an10 fittings for the rocker breather for pcv. deleted oem pcv. anlso deleted the little bridge that goes between cam covers, was annoying me as it was foiling one of the coils also i fitted the fuel lines up tidier mounted alot of stuff properly {} {} {} {} very fast made up a throttle cable bracket just to see i will make a heavy duty tidy one from stainless now i have measurements good oh yeah the cool switches too ha {} i have to mount my 2x spal rad fans next and im doing something very fancy as regards the pcv breather system so watch this space. hopefully this little thing holds up {} also an brake lines from chase bays . chase bays braided power steering lines and reservoir and coolant overflow bottle
pretty much brings it all to date so heres how my baby sits waiting for mapping april 2nd {} {} ill keep this updated as we go
