Chaps I have decided to break my MX5 drag car, as it's just not getting used enough and sadly worth more in parts than as a whole! So I have a low mileage 1JZ Non VVTi engine for sale, which was bought from JDM Distro in Ireland last year. The car has been out only a handful of times since this engine was fitted, and made a healthy 520hp on the dyno, so it's had a pretty easy life! Note lower oil pan has been re-fabricated to fit my vehicle so you may want to put a different lower pan on. The engine can be available in 3 guises, depending on what you want though I will give preference to anyone who wants the complete engine rather than me splitting it, so; - Option 1: 1JZ Non VVTi engine, Brian Crower 264 Cams, HKS Pulleys, ATI (Titan Motorsport) Crank Damper, new Toyota water pump, new timing belt tensioner, front sump. £1950 - Option 2: 1JZ Non VVTi engine, Stock Cams, No Pulleys, ATI (Titan Motorsport) Crank Damper, new Toyota water pump, new timing belt tensioner, front sump. £1450 - Option 3: 1JZ Non VVTi engine, Stock Cams, No Pulleys, No Crank Pulley, new Toyota water pump, new timing belt tensioner, front sump. £1250 Also, R154 box, Extreme Clutch and many 1JZ / R154 related goodies and AEM EMS Standalone ECU etc available soon... NOTE will be available JULY 18, as moving house at the minute... Can be heard running before engine removed if you wish, and cash on collection only, no delivery available (can't be arsed, simply!) Cheers Chris 07917 730525
Yes, its still up for grabs. Had to modify it to fit but made 520hp easily at 1.4 bar. £100 if you want it. Cheers
PM me if serious about it. Had a few PMs already. AEM is nearly brand new, bought from Driftmotion only last year. Cheers
Yes, but holding off selling at as a few people have enquired about the whole conversion. Will let you know if and when it's available...
