{} {} {} {} {} {} Up for sale is my comp spec Jzx90 cresta. Reason for sale is I do not have the time to use it as it should be used. No silly offers as I am in no rush to sell but would rather see it be used as a drift car than sat collecting dust. MOT just run out but i will be putting it through a new one before sale 600hp ENGINE Syvecs ecu running with toucan touch screen display mapped by mb automotive, all gauges on display working except speedo as its not wired up 1jz non vvt Hks 256 cams and gears Hks fine tune timing belt Audi coil packs Hks Injectors, Walbro 400LPH fuel pump CDF Racing 2jz pulley kit 2jz waterpump and alternator 6 boost manifold Garret gtx3076r turbo with braided lines External wastegate routed back into the exhaust Huge alloy rad with twin electric fans, one on a stat and one on a switch Greddy oil cooler with relocated filter Front mount BLITZ intercooler Full 3 inch solid fabrications exhaust with v band connections from turbo and back box INTERIOR Full weld in comp spec roll cage by Nickson motorsport Recaro and omp bucket seats Takata harnesses driver and passenger Driftworks hydro handle and wilwood master cylinder Keys racing steering wheel Fire extinguishers, on pull cords Cut off switch Carbon look door cards DRIVETRAIN R154 gearbox manual conversion (may need new thrust bearing washer for 1st gear as it does jump out but has never bothered me) Short shifter D1 spec gear knob Cusco 2 way diff SUSPENSION Aftermarket grooved discs and yellow stuff pads Hsd monopro coilovers lock mods: Daigo saito hey man knuckles Extended lower arms, polybushed Uras tie rods and supernow tie rod ends with custom adjusters made from aero grade alloy IS200 tension rods Kfd camber arms Hardrace bush’s Subframe locking collars Ultra racing 8 point underbody bracing, fully stiffens up the chassis I may have missed bits but thats all the main spec off the top of my head. Awesome spec car which has never let me down, i just dont have time for drifting and is a shame the car isnt used often so im looking to sell Exterior Respray in individual bmw pyrite brown in September last year New body kit, vertex lip kit and skirts and rocket bunny v1 rear and v2 front arches Work cr2p wheels 18x9 front 18x11 et0 rear with Splendid semi slick tyres 265 rear and 225 front The car will come with spares if asking price met: Front end (headlights, indicators, bonnet, front bumper, rear lip and anything else i may have) solid diff bush’sseveral tyres 265/18 all brand new, from semi slicks to atr sports Bad points: it is a drift car so do not expect a mint show room condition car, the pain is orange peely in places and the car is over 20 years old but even saying that it is in great condition with very minimal surface rust. As stated above 1st gear does pop out under clutch drops, this is the thrust bearing washer that needs replacing and costs pennies. I have not had the time to do this but it has also never bothered me as 1st still works as it should. Lastly it does need a clutch, the current one is on its lasts legs. If asking price is met I will have one fitted for the new owner, or a cheaper deal can be made as it is as time is not on my side. Looking for £13495 including all spares! Message me on 07515105541 for more info, videos, pictures May swap or part ex for the right car (can also add cash)
