For Sale S14 rolling and running project
Thread in 'Drift cars for sale' started by jackg16, Oct 13, 2018.
  1. jackg16
    jackg16 Member
    Thinking about letting my s14 go as I've moved away and won't get time to finish it.
    Shell needs some work but engine has been fully rebuilt and is running. Shell is in the middle of a tube and tub front end and the rear arches re-lining.
    Engine: (work done by Redman engine centre Fleetwood)
    Stage 1a Sr20det black top (Horsham developments chipped ecu)
    All new engine oil, oil filter, fuel filter, gearbox and diff oil
    Engine top & bottom end rebuilt at 98k including:
    New valve stem seals
    Rebuilt T28*turbo with Driftworks braided lines
    Greddy profec 2 boost controller
    HKS adjustable actuator
    New piston rings
    Max speed*forged rods
    ARP rod bolts
    ACL bearings
    Genuine Nissan crankshaft seals
    New genuine Nissan water pump
    New sump gasket
    ARP head bolts
    Tomei 1.2mm head gasket
    Tomei rocker stoppers
    Genuine Nissan rocker cover gasket
    All new Gates belts
    A/C fully removed
    Aluminium radiator
    Battery in the boot
    New exedy 3 puk clutch
    Freshly skimmed Competition clutch lightweight flywheel
    Balanced crankshaft
    Walbro 255 fuel pump
    FMIC
    Strut brace
    Engine damper
    Welded VLSD
    Copper plugs
    Oil catch tank
    Retroshine rocker cover
    Genuine Nissan gaskets, exhaust and inlet gaskets
    Chassis/suspension/exhaust:
    S14a kouki rear lights
    Carbon fibre boot
    Engine bay re-sprayed black
    Dmax roof spoiler
    Dmax rear bumper
    Dmax side skirts
    Oem front bumper
    50mm overfenders
    25mm wider front wings
    Driftworks thicker steering rods with 6mm spacers incorporated.
    HSD coilovers
    Brand new track rod ends
    Driftworks, 7twenty, japspeed adjustable*rear arm setup
    Polybushed subframe and diff
    Driftworks front tie rods with 6mm spacers
    Japspeed stainless manifold
    Japspeed stainless elbow
    Japspeed downpipe 3''
    Japspeed stainless centre section 3''
    Japspeed shotgun box
    Interior:
    Bride brix 1 drivers seat
    Nismo gear knob
    Dw steering wheel
    Wheels/tyres/brakes:
    X5 lexus is200 wheels with tyres
    X3 oem wheels
    X2 25mm spacers
    X2 30mm spacers
    New front discs
    New mintex pads front and back
    Can be seen running but hasn't been out since February this year.
    Can go with all running gear.
    Not sure what it's worth in the current condition. As I'm living away from the car, breaking it would be an issue but could sort do it at weekends.
    IMG_20181009_204058_292.
    IMG_20181009_204058_302.
    IMG_20180822_202946_465.
    IMG_20180623_181140_964.
    IMG_20180604_143311.
    IMG_20180604_165905.
    IMG_20180624_150542.
  2. dandadude
    dandadude Active Member
    And i've just shagged the queen..... There is making an offer and then taking the piss lol.
    • Like Like x 1
  3. jackg16
    jackg16 Member
    No
  4. wayner199
    wayner199 Member
  5. Aled Davies
    Aled Davies New Member
    still for sale?
