Hi guys, The adjuster on my cs2 coilovers seized and snapped whilst trying to get it moving. Can this bit be replaced? If so what is the process? Thanks {}
Hi there! These can be removed and replaced with a new piece, you can find these here on the store - https://www.driftworks.com/hsd-click-adjuster.html Let me know if you have any issues fiting! Cheers Fraser
Thanks Fraser, assuming i can therefore simply replace this without anything leaking out or needing regassing?
Hi there! that's right, the DualTech/Monopro's are sealed units so there is no danger in removing the click adjuster! Cheers!
