The time has come to sell my s13 due to buying a house (sad but happy times) I have owned it for 4 and half years and was road legal but due to only driving to drift days I bought a recovery truck, hence no tax or MOT. I have the v5. engine : * 1UZFE-VVTI conversion (290hp/310lb torque standard power) * de-immobilised ecu with auto gear box emulator * Apexi air filter * straight through exhaust * alloy radiator with twin fans * oil cooler * IS200 manual conversion * light weight fly wheel, ACT high pressure clutch plate, XTD 6 paddle friction plate Chassis / drive train *HKS hyper max coil overs * front adjustable castor arms * rear adjustable camber / castor/ toe arms * modified knuckles * 25mm extended lower arms * solid rear subframe bushes + solid steering bush * skyline 4.1 welded diff and shafts with solid mounts Wheels * 17x9 et 30 (rota copies) * 25mm front spacers * 30 mm rear spacers Brakes * s14 front 4 pot conversions * standard rears Exterior * aero front bumper * 25mm front wings * 30mm rear over fenders * after market side skirts * 180sx kouki fibre glass rear spats * front crash bar interior *Corbeau driver seat with takata harness * passenger bucket seat * dash dodger 6 point roll cage * after market rev counter * defi ZD (fake) There are probably lots of stuff I have missed, all in all its a very tidy drift car. If I am being critical there is an input shaft wine one the gear box which goes away when the clutch is pressed. I will supply a spare gearbox with the car. I have still drifted the car like this and it has been absolutely fine. I can whatsapp a video of the car drifting if needed. The car will come with black rear wheels and not the white ones pictured. (same as fronts) Any questions please ask. £6000 07772506098 {} {} {} {} {} {} {} {} {} {} {}
forgot to mention, it also has a walbro fuel pump and has been resprayed in ford frozen white. I have had a look under the car and it is all solid apart from a tiny hole on the n/s/r outer sill. i will happily jack the car up for any one who wants to take a look.
