For sale 2004 is200 1uz vvti Mot till December Car drives ( it's used some days to get to work).Had alot of time and work spent on it but needs a few things done to finish it off. So here's a bit about the car It fitted with a 1uzvvti from a 2000 ls400 which is wired up with a pheonix management wiring loom and unlocked ECU ( plug and play). It has a homemade exhaust system which dose the trick and sounds pretty good. cad Has lexibreak conversion kit to mate 1uz to standard is200 box. Modified celica gt4 flywheel with a mr2 turbo CD racing stage 2 clutch ( only fitted in december). Its sitting on hsd monopros which were bought in November . Car will come with rota torques wrapped in uniroyals. Bodywork wise it's a little bit rough especially around the arches and interior isnt 100% due to dashboard being pulled out for wiring . Cars also fitted with a hydro handbrake and a welded diff. The car is needing a few things to finish it off . Its needing a knock sensor and could do with a bit of a tidy up on the bodywork and interior unless you plan to use it for the track. If you have anymore questions just drop me a message and I'll get back to you as soon as I can Price £3000 Car is located in Falkirk scotland {} {} {} {} {} {}
That's the knock sensor error if you have anymore questions can u email me at jason-kay@hotmail.com thanks . {}
I've sent you an email mate. Check it isn't in your spam as my email address is wierd as. Just titled lexus
