1997 JZX100 Tourer V Imported earlier this year. Arrived with an oil leak and a fuel leak... both of which have been completely rectified since (new injector seals fitted after being ultrasonically cleaned as they were out, vvti sprocket rebuilt with new seals and new cam angle sensor). Starts first turn of the key and sounds great, a very healthy engine. Plenty of power as you would expect and drives as it should. There is a small dent on the lip of the near side front wheel arch lip which would be an easy repair with just an arch roller. Ultimately this is a cheap chaser which can be driven immediately. It's cheap enough for you to spend a few quid on suspension, exhaust and whatever else you want to make it your own car. Or keep it as a sleeper The price includes registration as you as the first UK owner, mot and tax. Please don't ask if it's manual... for £5k of course it's not manual, also you can clearly see the auto shifter in the picture {} {} {} {} {} {} {} {}
