Imported in 2003 Selling this as I no longer have the time to finish it. Was building it with intention of turning it into a competition drift car. The car was fully stripped to a bare shell and redone from the ground up. All welding repairs were carried out and the full under side coated with 2 coats of underseal. Nearly everything has been refurbished or renewed. Full welded in BDC spec roll cage done by miller mods. It can all be seen on my Driftworks build thread - https://www.driftworks.com/forum/threads/4dr-r32-rb25det-neo-bdc-spec-build.257771/ {} {} {} Spec – RB25NEO (compression checked) GT35 REP Turbo Top Mount Exhaust Manifold Front Facing Inlet Plenum NEW HKS Timing Belt and OE Water Pump NEW Auxiliary Belts NEW Short Shifter NEW Competition Clutch, Master Cylinder and HEL Braided Clutch Line NEW Competition Clutch Lightened Flywheel NEW Nismo Engine mounts GTR injectors NEW Oil cooler and thermostatic sandwich plate NEW Fuel Pressure Regulator? NEW Walbro 255lph fuel pump Turbosmart external waste gate NEW Alloy Radiator NEW Twin Electric Fans NEW Driftworks Polybushes 30mm Extended Front Lower Arms “HeyGlen” Modified Front Subframe NEW Super Pro Steering Rack Bushes NEW Adjustable Suspension Arms NEW Hicas Delete Kit NEW Driftworks Geomaster Hubs NEW Front Wheel Bearings NEW Solid Rear Subframe Bushes NEW Solid Steering Column Bush NEW HEL Braided Brake Lines Full BN Sports Kit Will come on VOLK wheels not the rotas as pictured in the build thread That’s as much I can remember of the top of my head. This is to go a complete package, I WILL NOT SELL BITS SEPERATELY. We’ve had the car running very briefly to test the wiring loom. The engine loom just needs tidied up and fiited properly. All other wiring is back in the car. Oil cooler and Heater matrix. Will need some form of aftermarket ECU but we had it running on the standard ECU. Everything else is mostly cosmetic. Will come with all panels and doors etc that were on the car and even the original interior. Looking for £7000ono. In no rush to sell and if it doesn’t I’ll finish it one day Located Falkirk, Scotland Will need trailered away Any questions feel free to ask, call or text me on 07969980220
