E36 Saloon shell NOTE : Rear work wheels are NOT included Completely rust free , Underside all sealed / painted Full Weld in cage with X door bars , rear bar and tied into subframe mounting points Rear turrets (shock mounting points) strengthen and tied into cage to allow a true rear coilover to be used Subframe mounting point strengthening plates welded in Rear trailing arm strengthening plates welded in Sunroof removed / plated and filled (Some of the filler has sunk see pics ) Intercooler and oil cooler mounts welded in. Rear bulkhead behind rear strut towers welded in Boot floor removed and plated over with plastic sheet Hydraulic handbrake mount welded in Lightweight heater box Polycarbonate side windows New front and Rear glass Front and rear overfenders Full M-sport kit Dmax style bonnet vent smoothed into stock bonnet with aero catches (Some cracks in filler work see pics) Bootlid is vented ( I have a fibreglass boot skin that will go with the car) Front + Rear lights v5 present (Shell originally 318) The complete car , engine bay and interior has been painted BMW techno violet , This is showing some signs of wear as the shell has been stored outdoors but should be very presentable when cleaned up. The tube work where the subframe has been tied has just been painted black as this was done at a later date to the cage. Will come rolling. I have a load of parts that will come with the car e.g. trim pieces , Wiper motor etc etc. Please remember this is a bare rolling shell with no wiring loom , fuel tank or lines etc. Great base for a ground up build with a JZ / V8 / S54 Etc. £1400 Please PM if interested. Collection from Trowbridge Wiltshire See my other listing for Braided line kit and Porsche Big brake kit. {} {} {} {} {} {} {} {} {} {} {} {} {} {} {} {}
