PCD converters 4x114 to 5x120
Thread in 'Technical Questions' started by Airbog, Aug 19, 2010.
  1. Airbog
    Airbog Member
    Hi there,
    is it possible to get these somewhere?
  2. Bolf
    Bolf Resident Nut Job.
    you want to fit bmw wheels on a s13? should be do-able , but you'd need a special wheel stud/lug setup on one of the 5 studs to get around the 4/5 stud issue.....
    Might be expensive. 5 stud to 5stud is much easier.
  3. Airbog
    Airbog Member
    Yes. BMW wheels on S13.
    BMW wheels in decent offsets are much easier to find.
  4. Bolf
    But don't forget the spacers will be 25mm , making a typical bmw wheel (et13) into a et minus 12.
  5. r3k1355
    r3k1355 Well-Known Member
    Give Rare Rims a shout, I've heard they can get custom spacers made up.
  6. Captain Muppet
    Captain Muppet Pro-tard
    If you're happy having spacers then you don't need low offsets. Just get massive 4x114.3 spacers and fit cheap easy-to-find high offset wheels.
  7. Airbog
    Airbog Member
    S13 will have 20 and 50 overfenders, so minus ET (for rear) is OK.
    Thanks for info.
  8. Captain Muppet
    :D Cool, that's a lot of wheel arch to fill.
  9. Stanislovas
    Stanislovas New Member
    5x114.3 to 5x120 would be easy, but it's impossible to make simple 4x114.3 to 5x120 adapters because allways one hole would be on other. There are only two options:
    1. Make those adapters, but leave wheel only with 4 bolts.
    2. Make two piece adapters. You attach one piece to a hub, ten second piece to first piece, then wheel to a second piece. In that case adapters will be thick, also you'll have 14 bolts on each wheel.
    For 4x114.3 to 5x114.3 will be easyier, then one hole will be shared. You'll need to install long stud in your hub for that hole.
  10. tomsheen
    tomsheen Active Member
    Christ lad your replying to someone from 2010 ‍♂️... why can’t people read dates
  11. Stanislovas
    So what? In 2020 people aren't using wheel adapters anymore?
