My jzx100 up for sale/swop ideally after a ps13 or s13. Feel free to try me though. Or 10k sale price. I have a video of the full car. Cold start etc but it wont let me upload it. If you are interested in seeing the video let me no and i will send it via whatsapp Bc coilovers Hardrace front camber arms Rack spacers Gs300 track rod ends Japspeed extra cranked tension rod Rota pro r wheels in matt bronze Vertex rear bumper Rear jacking bar Obd hydro 625 cylinder Willwood bias valve Complete new brake lines throught the car Apex strut brace Extended lower arms Bolt on knuckle adaptors Driftworks steering wheel 530d gearbox M5 v10 twin plate clutch and flywheel 1jz gte vvti Hks boost controller Hks turbo timer Full interior. Centre consol isnt fitted due to hyro and bias valve. Aluminium 48mm radiator Blitz intercooler Full stainless 3inch exhaust system Welded diff 1 piece prop {} {} {} {} {} {} {} {}
Hi pal. Got my 98 jdm s14a for swap of thays any interest to ya. Thanks. https://www.driftworks.com/forum/threads/98-jdm-s14a-silvia-sale-or-swaps.280826/
It did mate yeah it was from the drain bolt. The copper washer had split. Doesnt leak anything no more. I have a full video of the car and can get pictures to prove/answer anyone's questions
Diff ratio is 3.9 i believe as its the auto diff. The gear box im not sure on the ratio but i personally think its perfect for drifting. 1st gear is pointless as its too sort so start in 2nd. All the gears are slightly more together than usual and final drive isnt that good as with the set up runs out at about 125mph in 6th
