{} {} {} {} {} Up for grabs is my 200sx s13 that I was going to use as daily/drift car Fully rebuilt ca18 not even done 100miles 84mm wossner pistons Max speeding rods ARP head studs Acl rod bearings New valves & springs 1.5mm tomei head gasket Oem oil pump Oem water pump Gtx2860r turbo Tubular manifold Poly mounts Mishimoto rad & fans Lite weight flywheel Braided turbo lines Gktech abs delete All new hoses Horsham stage 2 chip 290bhp Walbro 255 fuel pump Exterior V2 rocket bunny kit 18” jr alloys (maxxis tyres) Jap speed tie rods Japspeed camber arms Japspeed toe arms Tein coilovers Japspeed quick shift White line rear camber arms Driftworks braided brake lines Poly bushed subframe Front strut brace Interior Brand new sparco r100 seats Apexi cage D1 gauges Aem wideband Greedy profec controller Short shifter Turbo timer Snap of steering wheel Rear strut brace It’s had new battery G40 coolant Wipers Gearbox oil Engine oil Clutch fluid Brake fluid all in the last week 12 months mot Been used as drift car so the body works got some marks mainly the front bumper Engine was built 100 miles ago still running the engine in, Would recommend remap once engine ran in for more power Cars currently sat in storage unit as I work away a lot and it’s just wasted. Cars located in Cheshire
I can do like £200-£300 every 2 weeks and we can make it like contract email rhys.richardson56@icloud.com
