Sr21det Z32 pistons Trust cams MLS gasket nismo 550 Apw mid mount waistgate priority full v band Puslar gtx2871r tial .64 rear stainless housing Gfb 38mm waistgate, Manifold, turbo, wastgate only done Dyno and maybe 300miles Gs6-53dz box Pmc box adapter Sachs clutch Full BMW probshaft modified Custom gearbox mount Shifter Been in car around 2 year and only done a hand full of track days Can go with rom and z32 maf hks gtrs turbo was 400ps when build and bought from power vehicles as it's currently on ECU master black that I plan on keeping however if someone needed full set up I can supply aswell full turbo set up £1500 Full gearbox and conversion package £1500 Full Engine with other hks turbo manifold and hks gtrs turbo was sent to aet for rebuild decided agents it and bought the pulsar so turbo will need put back together, z32 maf, nismo 550 injectors rom 400ps, £3000 Can supply s13 box and og giken twin plate clutch for above aswell price not sure talk to me, This is all still in the car and running for anyone needing to see it running, I can get more photos if needed Any questions call or message 07707181568 {} {} {}
How was that gearbox setup compared to stock box ratios?? Also is it a straight fit or does it need a touch of massaging?
I treated it like a dog box so pulling away in second and was ace but I had a 3.9 might have been better on a lower final drive, Yeah rubber hammer made easy work on the tunnel
Box out some photos Gs6-53dz 6speed box Pmc adapter and flywheel Sachs clutch Clutch fork throw out bearing Uprated clutch fork pin Auto flex plate Full BMW propshaft modified to work Custom gearbox mount, linkage and shifter All Hardwear Full bolt in job for a s14 Been in car for 2 year and done a handful of track days No longer needed can post anywhere at cost Call for any questions 07707181568 {} {} {} {} {} {} {} {}
Gearbox set up sold, Engine left witch I'm happy to keep I'll add photos when I get loom out car off all included
