Hi, I know this has been asked before but struggling to find a definitive answer. I've just purchased a 2003 E46 330i to use for drifting. Is there a difference in the DSC systems between older and newer E46's and will just holding the button until both lights (traction and handbrake) come on be sufficient to fully disable the electronics? Or will I need to go down the fuse pulling (or speed sensor disconnection) route? The car will be used on the road so ideally I'd like to retain the speedo which I understand the fuse method can cause issues with. Thanks!
