1.9tdi judder when gas pedal half pressed
Thread in 'Technical Questions' started by YashioFactory, Apr 11, 2013.
  1. YashioFactory
    YashioFactory Active Member
    Rhondda, South Wales
    had the car around 6 months, its done it since ive had the car.
    when driving, if i have the accelerator pressed say quarter of the way down, the car judders.
    its not a miss fire, only way i can describe, is asif your tapping the brake pedal the same time as the accelerator is pressed.
    if you press the accelerator further down, the juddering stops.
    i suspect a fueling issue, possibly filter. any other usual things likely to be? MAF?
    its got a new flywheel & clutch so its not that
    car is a 2001 audi a3 tdi
  2. cptsideways
    cptsideways Active Member
    N Dorset
    Try cleaning the injector nozzles ;}
  3. darrengodfrey
    darrengodfrey Member
    North Lanarkshire
    My car does this aswell but ive never thought anything of it i have a new clutch and flywheel aswell mines a 1.9tdi passat so same engine as yours.
  4. jumpbike
    jumpbike Member
    usually dual mass fly wheel has died, which can happen to a new one because duel mass is just such a good idea....
  5. MMC
    MMC New Member
    Galway Ireland
    No harm in changing the fuel filter,but once you've checked the obvious,id personally use some form of diagnostics to check for any problems
  6. YashioFactory
    my diagnstics shows no errors,
    the car has done it since ownership, before ive fitted a new dual mass, and after ive fitted a dual mass. so its not that.
    see if the fuel filter makes any difference
  7. superclarkey
    superclarkey DORITECH MOTORSPORT
    West Midlands, Halesowen.
    Possibly a turbo fault, Does it have a VHT Turbo ?
  8. luca24
    luca24 Member
    Gomshall
    Try with the MAF disconnected as that is a serious possibility on these
  9. YashioFactory
    not sure what turbo has sorry, im not really into german cars.
    i thaught something possibly could be with it, possibly when it comes on boost it goes on & off boost until the accelerator is presed further?
    boosts fine & doesnt smoke etc.
    i can live with the problem, just would be nice to have it 100%
    - - - Updated - - -
    will try later thanks
  10. magicmat
    magicmat Active Member
    W.Yorks, Wakefield
    I bet its maf, causes all sorts of probs you'll need to borrow another
  11. YashioFactory
    ok will do. can i unplug it to test? or does it need another to run
  12. MMC
    MMC New Member
    Galway Ireland
    What kind of diagnostics are you using?,is it a simple code reader or something that can read live data?some other things you could check
    for would be dodgy vacuum pipes going to the boost valve or the boost valve itself,as said MAF sensors are pretty common,also check the gauze before the MAF seen this partially blocked not that common but have seen it happen,could be worth doing a boost leak test and check for any air leaks between MAF and turbo
