Hello im currently building an e36 bmw track car with a 1jz engine and r154 box fitted< the loom I got with the engine has been hacked about I believe for an emanage install, I have stripped it all back resoldered and heatshrinked. The problem I have now is working out what I need and what I can remove from the loom, the whole car has been stripped an will be having a custom loom made up so Im starting from scratch with everything, I have found the pin outs picture from google and worked out the main ECU conections X, W, U, T , plugs (dont have and ECU for it yet) I am struggling to work out what the rest of the conector blocks are, I have labled them A B C D ect for ease any help will be great I have also found this link which I hope Identyfy a few of them? Supras.nl - [Modifications -> Other engines] 1JZ Swap report
im not too sure this can help you. the plugs can be for the TRC / ABS wheni remove the trc and abs ecu, the plugs looks like yours F and B
When I was building a soarer 1JZ into my e36 I used this page for identification of plugs: **How to wire a soarer 1JZ into MA70**** Your loom looks different from mine though, from what car is your engine? I also used another wiring diagram that I cant find anymore. But this one also looks usefull: http://www.jzgte.com/tech/1jzgte/1JZ-GTE.Wiring.v1.1.pdf
http://www.jzgte.com/tech/1jzgte/Soarer.pdf You have a JZZ30 Loom there NOT a JZA70 loom I have all the wiring diagrams email me (not PM) & I'll buzz them over
my origional loom that come with the engine doesnt appear to have knock sensor plugs did they do a 1jz with out these as I dont have the knock sensors either??
not sure if your still weird about the knock sensors or if you've figured it out yet but there is two knock sensor right on the block on the intake side... the actual wire to the sensors is a shielded wire... so it looks like a clear wire
Hi there, I am getting a 1jz put into my s14 and I also need some help identifiying exactly what engine loom and ecu I have. I sent you an e-mail.
Hi sorry to dig up a old post but do you still have all the wiring diagrams avalaible? Im trying to wire my 1jz from a jzx100 into my mazda rx7 fd
