bargainus. Incase anyone thinks its pikey, its a big thing in america for the hot rodders to use on big blocks. Regulation hokey pucks are polyeurethene. I have 3 on each side of mine with a 400hp rb25 sat on top of it. Solid as a rock.
i actually have 24 of these now, just found the ones i thought i sold ages ago lying in the back of my garage So if anyone wants any let me know, same again £7 a pair (thats two hockey pucks to the dumb) Posted anywhere in UK
I used two per side and about 8-10mm of washers to sit it at the right height. You could fit just two per side and drop the engine a touch meaning you'd have better centre if gravity
yup same here, 2 and a half will replicate stock mount height but squeeze 3 in and gain more clearance to drop the car some more and lower your centre of gravity
I've used one to stiffen up my gearbox mount !!!!! Just cut it to shape and slid it in hollow part of the mount (the 2 mounting bolts hold it in place)
been running them for 3 yrs and all u need to do its just tighten them up everynow and then btw this dan chapman on jacks account
just so ppl are aware these dont fit s14's as sr engine mounts are offset. they work on redtop sr's in s13s
ah ok then. I was told that they wouldnt work when i asked dean to do it on my 32 ( s14 subframe and sr20 ) he said it would/didnt work and same on his s14 ??? i stand corrected then
