Hello! I´m building my second drifting Supra. The last car i had are trash now and i just started to build a new one mutch better. The car is going to compete is the northern europe and i hope to come to england also Car: Supra A70 -91 Motor: ls1 v8 from camaro ss and t56 trans. the motor is going to be relocated further back and the fuelcell is going to be mounted behind the seats. the water cooler is relocated in the trunk chassi: Fully adjustebal chassi with stuff from XYZ, A1, meganracing and more.... I have build my own arms in the front and customized the steering alot Body: homebuilt widebodykitt in fiberglas and carbonfiber, 100mm in front and 110mm rear. homemade carbonfiber roof and other panels. the body will be cut in frónt and rear and a new tubeframe is going to be welded inside: rolecage and new built floor and firewall. standing pedalbox and homemade stuff my older car that is trash now one more The new project the work is in progress and spring 2012 is deadline i hope you guys like it. regards Tobbe
yes the first car i crashed in latvia but i fixed it after and it was not so bad as i was afraid of. In June i was driving at Gatebil sweden again but then i bumped in to a wal again and fixed it again and the i compete in sweden and the engine had some failure and i started to build a new one !
My new engine trans package is on its way. New Rota GTR-D rims also. I have stuff from horsepowerfreaks on its way also. A1 rear adjust arms The rolecage is soon finnished also. enjoy! regards teamgtdr.se
The engine has arrived to the garage and the rolcage is done! More things on its way from the states like, clutch, headers..... enjoy! Regards tobbe teamgtdr.se
The engine is now at its place and bolted in to the car. Have also started with the floor and the firewals. My homemade widebodykitt are soon finnished also. regards Tobbe/www.teamGTDR.se
Got some work done in the garage now. Firewal, floorpanels exc is done just some welding left. I also did some loose panels so that i can work whit the engine if i need to. This is how my new fenders look. I have starting out with the mals for fiberglasing also. If someone like to bye a pair from me just contakt me Regards tobbe
The fiberglasfenders are done and i have started to cut to old fenders down and rebuild some new once. regards
Hello! The front and rear subframes are remanufactured and in place. The diff is done and alot of small stuff. Inside of the car is soon done. A little peak of the inside and the firecell regards teamgtdr.se
