Yes, and PowerFC Pro for sale. (The Power FC Pro Spec.CPU has been designed for drag racing use. These units have two additional functions over the regular units: 1. Ignition cut used for rpm limiter - Regular Power FCs cut fuel feed when the preset revolution limit is reached. At high rpm, there is the possibility of knocking when the fuel is cut in high-powered cars. The Power FC Pro CPUs cut ignition at the rpm limit to prevent the knocking that could potentially destroy the engine. 2. 0km/h rpm limiter setting - Allows for the setting for an initial rpm limiter that is active whilst the car is not in motion. This allows for mainting a rpm level for consistent launches.) I need a quick sale!! **Comes without handcontroller** 699GBP I am from the netherlands, shipping will be around 20-25GBP to the UK.
