Hello, sorry is this suppose off topic? Basically i'm about to buy exhaust and it 90mm. So the seller still looking for reasonable shipping. have anyone bought large item from USA before and which shipping comany? I'm looking to spend under £150 post to Uk from USA. So which company is cheapest ? Cheers
The problem is posting to and from the states is that it has to go via air, also the calculations for the weight is worked out on the greater of either actual weight or volumetric weight, the volumetric weight (which is the length X width X height then divide that by the carriers amount (usually 5/6000) that will give the volumetric weight) which in both cases sounds like it will probably be alot more than the actual item. Basically, stick it in a box as small as you can I'd give FedEx, UPS and DHL a go for prices
