Hey Peeps ! My name is Patrick and im from Denmark. One of my Danish friends recommended Driftworks homepage, so I hope you will welcome my project. I hope you understand my bad school English, if not - then just throw a comment and I'll try to explain i another way Smal facts about the car: BMW e34 M5 Supercharger by Rotex JE Pistions Titanium connecting rods Steel top gasket Worked cylinder top and intake ECU by Flemming Fastrup 3" stainless exhaust system Intercooler Adapting to front bumper The next project is silicone for supercharger system - Update will come, later because i need to make aanother supercharger bracket. I started to update, so I save regularly!!
Now it's time for an blow off project The new valve have a adjustment of a material we do not know about, so instead of welding in a material we do not know, we make a new adjustment. On the pic you can se det sdjustment part. Let's start with a piece of aluminum Now i almost fits on I started to update, so I save regularly!! - More to come !
The Danish crazy friend would not happen to be Mr-RX7? Thanks m8 - and HELL YEAR we see ya at the battlefield !
Aem widebrand probe Saftey Board clock Supercharger bracket painted with primer Bracket on engine and painted I started to update, so I save regularly!!
Bosch fuel pump Exhaust silencer New Oil filter bracket I've talked to a few people, and they believe that the variable intake system should be removed because it tends to cause problems when you build pressure on, so out whit the problem Inside, I removed the plate that is controlled by vacum system
What I got from my sweet girlfriend - Sparco gloves The next project is to renovate the gearbox, synchromesh is not in good condition longer Stay Tuned !
You are absolutely right! I expect the car to have a completely new design- Then i wil remove the spoiler and get a new one :b
Love e34's! My daily is only a shitty 520 but it just won't break and never lets me down. Looking forward to seeing what u do with this.
Awesome build man, I like the FMIC. I may have to use a similar one to replace mine at somepoint so my pipes can sit a little higher. Ive been thinking about making my headlights singles aswell for more air, how did you do yours?
