I have the following for sale : facelift front bumper, comes with or with out lights, painted black , no splitter , has a hole cut in the front for a towing eye to come through, £10 . Can post aslong as you arrange courier. otherwise pick up only uk spec rear bumper, painted black as well , good condition, can supply rear number plate lights as well. same as above regarding posting . £5 2 sets of headlights : fair condition, not mint but good and functional : £20 per set or £30 for the lot ( can post at your expense) Ca18det exhaust manifold : £5 collection or courier at your cost 2 sets of facelift indicaters : £10 random side skirt : no idea of make, only one , courier or collect : £15 brand new lambda sensor : not official Nissan but easy to wire up, guide is on DW some where £20 , can post at your expense vented headlight cover , mounts are damaged and has cable tie holes : £5 ca18det radiator : is not pretty has a fair few bent fins but works fine £5 plastic covers that go on the pillar behind the front windows: £5 Skyline r33 mudflaps : no bolts but good condition : £15 believed to be sr20 starter motor : £5 ca18det coil packs, metal frame and loom working when taken off the car : £10 2x ca coilpack covers :£5 each switch panel that incorporates 2 aircraft switchs and a starter button and 2 lights : £10 2 x maf's , 1 - 3 pin 1 - 4 pin both came off working cars : £10 each s13 wing mirrors, good condition both casing and mirror, £5 s13 windscreen wiper motor : £5 ca18det rocker covers £5 s13 windscreen wiper stalk £5 All small items are postable aslong as you cover cost's , all items will be sent the day after payment recieved and will be sent signed for. larger items collection from NR11 or you arrange courier
windscreen washer motor : tatty but working £3 s13 rear section of centre console, few storage marks £5 s13 interior light £5 s13 standard ECU £10 s13 door handles with lock and key £10
Hey mate could be interested in the lambda but do you have the other side of the plug and wiring loom aswell? Thanks
Yes mate the part of the engine loom, the wiring both sides of my plug is worn so I need to replace the lambda and the loom the other side
ill need about 6 inches the otherside of the plug just so I can wire it into my loom easily. It is for a ca18det yea??
No worries that will do for now then, can pay monday if you want to PM me your bank details I will do it first thing
