Dan200s14 AAA s14a build
Thread in 'Project Cars and Builds Threads' started by dan200s14, May 16, 2012.
  1. dan200s14
    dan200s14 Member
    Hi people just thought I would start a thread on dw as I thought I had done so already but looking back I clearly haven't :wack:
    Right here are some pics of the car herself
    One just like her the day I first laid eyes on her
    http://i233.photobucket.com/albums/ee147/fcukdan19/396103-3.jpg
    This one the weekend after I baught it :-) back in 2007
    Front bumper sprayed
    http://i233.photobucket.com/albums/ee147/fcukdan19/03042008057.jpg
    http://i233.photobucket.com/albums/ee147/fcukdan19/03042008065.jpg
    Fast forwards to just after a minor accident and another respray
    Now except the fuel cap in white too
    Sadly the engine had been loosing compression and dieing a slow and painfull death :-(
    So had to come out!
    So I've now nearly got up to date on pictures so il just fill you all in on what's happened since!.
    She was running 350bhp 368ftlb torque which I was very happy with but had to sell ill my mods to get my new engine and bits.
    Good bye list:
    Fidenza flywheel & Rps paddle clutch
    Gt2871r .64
    Hks actuator
    Denzo 550 side feed injectors
    Nistune ecu board
    Z32 afm
    Apex engine and tran mounts
    Intake hard pipe
    + loads more I can't remember
    Parts for build:
    Soarer engine and all ancillaries (thanks Cptsideways)
    R154 gearbox(thanks to nooty)
    Front sump
    Ksracing mounts
    1jz ksracing bellhousing
    ATM I'm in the process of cleaning up my engine bay
    Then I will be fitting the engine and box to get a measurement for the prop.
    Will try to keep this updated on a regular basis.
    Thanks for reading :-)
    #1 dan200s14, May 16, 2012
  2. CSMDESIGN
    CSMDESIGN Member
    Good project mate. U still got the parts for sale? ive just done a full build, stripped the car to a bear shell, got rid of all the rust, engine rebuild the works check it out on here sumwhere :)
  3. dan200s14
    dan200s14 Member
    No mate all parts have gone now. Just saving to get a clutch setup and prop shaft made. Other than that I need to make an exhaust find a throttle cable and the rest is wiring! Im aiming to get it in running and road worthy within the next 2 months but I'm sure il hits snag
  4. PHIL-BLR
    PHIL-BLR Member
    Hey mate can you let me no how the ksracing mounts fit need a set for my r32 but no one has a set of jz mounts on the shelf in the uk cheers
  5. dan200s14
    dan200s14 Member
    Ok buddy well I'm hoping it's straight fit. Keep an eye on this thread just incase I get carried away and forget to let you know :)
  6. dan200s14
    dan200s14 Member
    R33 front brakes got fitted last night :)
  7. dan200s14
    dan200s14 Member
    Oh and trial fit the the 1jz mounts just to make sure the holes were big enough!
    Which they aren't so needed to just open them a little :)
    #7 dan200s14, May 19, 2012
  8. japmaddean
    japmaddean Member
    nice car mate
  9. ant_m91
    ant_m91 Member
    Nice car looks nice in white
  10. dan200s14
    dan200s14 Member
    Did lol she ain't looking too pretty ATM
  11. ant_m91
    ant_m91 Member
    Wil look good when all done
  12. dan200s14
    dan200s14 Member
    Here is the donor car
    Progress this weekend is minnimal but important
    Engine bay blasted ready for acid etch then zinc primer then high build primer, bit of sanding then paint :-)
    Here we have a picture of the engine block being prepped ready for front Sump conversion
    The majority of the sump fitting and drilling has now been done,I say drilling as the sump came from a non turbo engine so we needed to drill the oil return and tap a the thread to attatch it :-)
    #12 dan200s14, May 20, 2012
  13. dan200s14
    dan200s14 Member
    Thank you dw [​IMG]
  14. dan200s14
    dan200s14 Member
    White high build ;-)
  15. dan200s14
    dan200s14 Member
    Top coat
    #15 dan200s14, Jun 7, 2012
  16. dan200s14
    dan200s14 Member
    Getting all the remaining bits into one place
    [​IMG] minus engine
  17. dan200s14
    dan200s14 Member
    Spaghetti anyone? [​IMG]
  18. dan200s14
    dan200s14 Member
    Excuse the poor photos but..... Engine and box are in for a trial fit :-)
  19. counteract
    counteract -o=me
    Was this down at Luke's the other week getting getting painted?
    Nice looking car fella, I'm only in Cheddar so there's a chance I might see this about some time :thumbs:
  20. dan200s14
    dan200s14 Member
    Gearbox is back out again now to get the linkage extended 3 1/2" and for the flywheel to be fitted and variouse other little bits n pieces but it's coming together :)
