I AM OPEN TO OFFERS ON EVERYTHING!!! Pics can be provided on request or if your on FB then they are on there. I am open to offers on everything and prices do not include delivery. SARD fuel pressure regulator - £80 R32 skyline GTS OEM downpipe - £20 5x114 16" spare wheel - £15 R32 GTS pas rear spat - £35 (grey) 2 sender oil cooler sandwich plate - £15 RB20DET coilpacks - £85 RB20 Inlet - £60 Rb20 STD injectors - £30 RB20 big breather oultets rocker covers - £30 S14 SR STD boost solonoid - £10 RB starter motor - £60 RB20DET engine loom - £80 RB20DET 5 speed ECU - £80 RB20 alternator - £70 RB 2wd sump pan - £40 R32 GTSM rear spats Pair - £70 (blue) S14A SR ECU - £45 S14 fog lights pair - £20 2x multi fit audi rep wheels - £80 WRX scooby bucket seats on S14 rails - £100 R32 GTST front brake setup (calipers, discs, pads) - £150 SR cam oil feed spray bars - £35 T28 oem actuator - £5 2x S14/A oem intercooler pipework - £15 S14 cast elbow - £20 S14\A O2 sensor - £35 2x S14\A master cylinder - £30 S14 clocks - £10 S14/A pipercross panel filter - £25 SR starter motor - £45 SR power steering pump - £30 spitfire boost guage - £15 S14 grill - £15 S14 rear wishbone - £35 SR coilpack lom - £30 S13/32 diff back plate - £20 R32drivers headlight (broken brackets) - £35 S14 rear light pas and drivers - £15 each K/N big turbo filter RU3050 NEW - £35 (RRP £60) 2x s14 rads - £15 each SR rad shroud - £20 1x R32 rad - £15 driftworks front tie rod - £15 S14/A aircon fan - £15 S14/A recirc valve - £10 SR inlet rubber pipe - £10 3 x S14/A doors - £30 each 2 x R32 GTS doors (covered in carbon lookalike) - £40 each RB20 head (new stem seals req) - £60 RB20 cams - £50 RB20 cast manifold - £50 Civic EK/EJ exhaust spacer pipe - £20 R33 GTR braided front brake lines - £30 RB20DET flywheel - £30 RB20DET coil amplifier - £30 RB20 O2 sensor - £40 R32 GTR gearbox (not sure on condition, purchased from RK tuning as a spare) - £350 More to come
