ics up asap ( when the host site clears them) I was also wondering with the wide rear arches that rivet on to the body what happens with the original arch.... because presumably if your to low then your wheel will easyily catch the original arch... do you cut them out?... roll the crap out of them?... I honestly have no idea... sorry if its a stupid question.
Depends on application,overall desired setup,quality level desired,intended use/purpose.More specs needed,what type of flares,whats your wheels tire setup,suspension set up ect.
i presume you mean the jun arches on fleebay?? Id be interested in this also, although i have done some research and found that alot or most of people actually cut the arches out, reweld and seal, then fit the desired arches. Theres a few project threads on here which do actually have some great pics to give you an idea, but if someone whos actually clarify it would be great.
as above mate, you need to cut the origional skin higher re weld and seal if you want to lower the car without any chances of catching. their are some pics in my build thread if that helps as just done mine.
I've got tein fully adjustable suspension and was lookin at gettin some work xd9's And the arches I was checking were the 50mm AIT carbon fibre ones Just need to figure offset for the wheels to line up whith the arches nicely Also lookin to get adjustable camber arms on the rear n lean em in at the top a lil to line up just iside the edge of the arch Its a lot to do buuuut I'm definatly gonna make a move on it Thanks for the response every1... I'll check out your build bigmiker32 Thanks again
