180sx Sr20 keeps blowing ENG CONT fuse
Thread in 'Technical Questions' started by whi5p, Nov 30, 2018.
  1. whi5p
    whi5p New Member
    Hey guys,
    Recently go another 180 and I'm having a few problems.
    When I collected car I could hear clicking from under bonnet but I didnt think much of it (sounded like a relay). The car drove well for most of the 400 miles home then suddenly the engine would cut in and out while driving, shaking the car badly, then all appeared normal again.
    The next day I took the car for a run and the same happened except this time the car died and was recovered. The car would crank but I couldnt hear the fuel pump. Upon investigation the ENG CONT fuse was popped. I changed the fuse and it fired up, on a short drive the fuse popped again (took lots of spare fuses to get the car 2 miles home).
    My question is what devices are on the ENG CONT circuit? I have been searching allover the net for the last few days and I cant find anything (in english) that even resembles a wiring diagram for an SR20 180. If anyone could point me in the right direction so I dont need to examine every wire I'd be much obliged.
    My thoughts are:
    Bad earth? Short on o2 sensor?
    I noticed the connector block in the boot for the fuel pump was wet but I dont know that it was wet when this happened originally.
    I also noticed that when I replaced the fuse the other relay box (near pass head light) started fizzing, I immediately pulled the fuse however I cant replicate this now.
    Anyway, a wiring diagram or any and all advice would be great.
    Thanks in advance.
  2. whi5p
    whi5p New Member
    I forgot to mention that when hot the idle was crap. For example approaching a roundabout when you dip the clutch it would struggle and threaten to cut out. I'm not sure if this is related to the fuse problem but I though I'd mention it. Looks like I am going to spend the weekend with my multi meter regardless!
    Cheers
